Driver side door wiring question (trunk)
Old Jul 9, 2006 | 07:21 PM
Brooklyn Legend's Avatar
I havea 1992 maxima SE I changed the driver side door with a 1991 or 90 door because my 1992 door was damaged badly. Problem is 1992 SE has power trunk unlock on the side of the door panel the 1990 or 1991 has the lever for the trunk on the floor. Is there a way I can use the 1990 door to unlock my trunk. The 1990 door doesnt look like it has a harness for the power trunk. Also The key I have looks original but dosent unlock the trunk. It does unlock the glove compartment so I dont think its a valet key.
Any help is appreciated.
Old Jul 9, 2006 | 07:45 PM
internetautomar's Avatar
mod or sell?
1. you can swap the entire interior door panel which would include the switch.
2. the trunk locks tend to go bad on the 3rd gen not sure why though
Old Jul 9, 2006 | 07:49 PM
I have the 1992 door panel and switch (My car is the 1992) The thing is the door I just installed which is the 1990 doesnt seem to have a harness for the power trunk switch, so thats pretty much my problem the trunk release switch is in good working condition
Old Jul 9, 2006 | 07:52 PM
mod or sell?
do you still have your old door?
the harness should have been reused from your 92 door anyhow.
worst case you run some new wires
Old Jul 9, 2006 | 09:17 PM
[QUOTE=internetautomar]do you still have your old door?
worst case you run some new wires[/QUOTE
Yeah, I guess my only option is to run new wires as I got rid of the door earlier today. I was going to take out the whole drivers door harness of the 1992 damaged door but instead I only took the plug that goes into the trunk release switch.
Old Jul 10, 2006 | 04:53 AM
mod or sell?
at least it is only 2 wires
Old Jul 10, 2006 | 05:50 AM
I got two different answers from the faq's one says there is just a brown + wire in kick panel. the other says ther is brown + and light green and black wire.
I checked kick panel there is 4 or 5 brown wires?
which one is it?
Old Jul 10, 2006 | 08:38 AM
mod or sell?
well it has to be at least 2 wires
Old Jul 10, 2006 | 05:04 PM
shvelle's Avatar
Why wire it in at the kick panel and then be forced to run several feet of wire through the rubber gromet into the door?? Why not just splice into the power window motor harness (behind the door panel)?
King_Ten_Ahead
Sep 30, 2015 04:27 PM
Stelianos
Aug 19, 2015 02:07 PM
shaunkey1
Aug 18, 2015 10:09 PM
BassAddictJ
Aug 4, 2015 11:38 AM
