automatic a/c control
OK, my blower is working even in off. I disconnected the relay at the right panel below the glove compartment and continued blowing
does anyone know if there is more than one relay or why it keeps running?
The resistor is ok, I already replaced it since it was working in high only. When this problem happened the speeds started to get confused, 2 was 1, 1 was off etc.
PLEASE HElP!!!:attention
does anyone know if there is more than one relay or why it keeps running?The resistor is ok, I already replaced it since it was working in high only. When this problem happened the speeds started to get confused, 2 was 1, 1 was off etc.
I had a similar problem and what happend was when I plugged in the resistor the back of it shorted on a copper tube in there. I moved that tube out of the way slightly and all was well.
You may check that since you say you replaced it. Maybe something got moved around in there.
tarun900
19
Dec 20, 2021 06:57 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
