VG30E(T) Adjustable Cam Gears
Old Jul 28, 2006 | 02:10 PM
mtcookson's Avatar
If any of you are looking to squeeze every last drop of power that you can out of your VG... here are the only, fully adjustable cam gears for the VG30E out there.
http://www.jmsperformanceproducts.co...cam_gears.html
Another option, which isn't full adjustable, but does give you some flexability are here (roughly half way down under TSS "Morgan Style" TSS Adjustable Cam Gears):
http://www.thespecshop.com/store.asp...y&Query=Engine
Most won't need these... but they're another option for squeezing out some more power for those looking to do so.
Old Jul 28, 2006 | 02:13 PM
Jeff92se's Avatar
I'm needing a caw
Nice find.
Old Jul 28, 2006 | 03:11 PM
Matt93SE's Avatar
STFU n00b!
wait a little while and I'll have some for the VE.
Old Jul 28, 2006 | 03:15 PM
GRNMAXDMON's Avatar
how much for those puppies?
Old Jul 28, 2006 | 03:16 PM
GRNMAXDMON's Avatar
knowin' u Matt, ur just gonna design and build ur own engine while ur at it as well. lol.
Old Jul 28, 2006 | 04:26 PM
internetautomar's Avatar
mod or sell?
I thought the consensus was they weren't worth it on a VE
Old Jul 28, 2006 | 07:10 PM
Matt93SE's Avatar
STFU n00b!
probably not, but it never hurts to try.
Old Jul 29, 2006 | 08:38 PM
Chris Gregg's Avatar
Get Off My Lawn
Great Mtcookson..... You had to wait till I had my engine done to let us know! I'm picking up the finished VG30ET tomorrow! URRRRGGGHHHH!!!
Old Jul 29, 2006 | 09:54 PM
kcidmil's Avatar
Using common engineering knowledge, and if the VTCs are disconnected, it might be worth it to use for tuning the cams at the right point in the RPM band for optimum flow.
Or I could just use a term that makes sense to everyone... "It helps to make more power"
Old Jul 30, 2006 | 06:38 AM
Matt93SE's Avatar
STFU n00b!
Finished and in the car, or the engine is assembled?
either way, it's only about 3-4 hours to pull the timing belt and replace the cam gears.
Old Jul 30, 2006 | 07:52 AM
Hectic's Avatar
nice, i'd love to see a stock ve run against an otherwise stock vg with those suckers installed. ve would probably still take it, it'd be a lot closer of a race though.. i want a pair.
Old Jul 30, 2006 | 01:35 PM
Get Off My Lawn
Engine is assembled. I should have it dropped this evening and hooked up by tomorrow and started. I'll have to wait till I get my bearings replaced in the VE hubs later this week before I can drive it though. Either way, my wife is threatening divorce if I don't get it in the car and running! I just wish I could have planned for getting the gears. The van I am driving is sucking my life and wallet to death in terms of fuel economy!
Old Jul 30, 2006 | 03:30 PM
Greeny's Avatar
¯\(°_o)/¯
I call bs on the divorce thing...She loves maximas as much as you do...Shes just po'd that the engine is not going in her maxima..
You should have called me for help..
Old Aug 5, 2006 | 08:07 AM
Get Off My Lawn
Spoke to a guy the other day. He stated that actually, adjustable cam gears are most useful on stock cams. Indicated benifit is not as much on modded cams. My cams have been modified to a moderate cam. I'm sure that there is a gain in either situation, only that the gain is smaller with modded cams due to already enhancing performance of the heads/valves. Thoughts?
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
leatherneck
Sep 30, 2015 09:16 PM
