keyl;ess entry wiring
Old Jun 24, 2001 | 02:19 PM
Silence's Avatar
keyless entry wiring
Hey everybody i wanted to know if anybody has had any luck figuring out the wiring scheme for the keyless entry box above the pass. kick. I just installed a remote start and such to my car and used that box to splice in my lock/unlock, trunk, and siren (i used the piezo beeps the numbered buttons make) and drivers side window. I used this box cause it uses all grounded signals to activate. Its weird cause the buttons on the outside below the door handle opens all the windows but i can only seem to find the one for the drivers side at the keyless enrty box. I am thinkning that there are seperate wires for each of the windows but i cant seem to find them without going to the door panels. I guess the actual wiring diagram for the keyless entry box would be wonderful, besides im sure there has to be a place to find these such things
Old Jun 24, 2001 | 04:47 PM
Brandon90gxe's Avatar
Yep, same thing with my keyless. found the driver window wire in the keyless entry box, but there is no passenger window one there. i looked it up in my FSM and the wire is routed somewhere, i forgot right now. im gonna have my dad look at it and see what he sais, cause hes the one that helped me in the first place with it. but yea your right, you can only acces the driveres side wire from thebox, the passenger is somewhere else, if i find out ill let you know.
Old Mar 4, 2003 | 08:41 PM
ghostmax's Avatar
Re: keyless entry wiring
Question
I used this keyless entry box and wired the trunk pop to the one in this box, but the trunk still doesn't open when I hit the button. It seems like the solenoid isn't getting enough power. Does anyone have the same problem? How did you fix it?
Also, for the piezo beep for lock/unlock, did you wire the dedicated horn wire from the aftermarket keyless entry or the actual lock/unlock wires to the beep wire?
Thanks in advance for the help.
Old Mar 6, 2003 | 05:25 AM
shavedmax's Avatar
Re: Re: keyless entry wiring
Originally posted by ghostmax
Question
use the alarm wire to kick over a relay with a strong 12v wire to pop your trunk.
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
