Custom CAI (pics inside)
SHWELL
theres this thing at autozone and me friend did it to his FOX... and he bought a mock-up version to see if it would fit into his car
i asked him let me see if i can ALSO!
its 3inch piping customized to fit the MAF
there is
- Long Straights
- Short Straights
- 90 degrees
- 45 degrees
- 22 degrees
- Y-Splitter thingy for 2x cones lol
and i had to do some cutting for it to fit where i want it to go
and this is how far i got until i can borrow a grinder from my work
so sweet when i get it DONE!
there is
- Long Straights
- Short Straights
- 90 degrees
- 45 degrees
- 22 degrees
any better pics by any chance? my friend says he can make me a killer setup for the VG but he's a very busy person so I know its gonna take a while..I'd like to consider this option temporarily once I have seen more of it
guys... its a MOCK UP
sooo... its 3 inches
means i can test where i can put it before i buy the final fittings... and holes are in it so you cant buy this $10 set and USE it as a CAI
its not going to be "that cheap" but it'll be custom
Pff. nothing duct tape cant fix
Originally Posted by Cliff Clavin
I think you owe Jeff and MrGone money for stealing their idea...
http://forums.maxima.org/showthread....ight=cai+today
Originally Posted by MyGreenMax94
the database still has my name as Red92MaxSE (in MrGone's quotes)
I have the same CAI, but it has been sitting in my garage for like 2 years. I just used the first piece for my pop charger.
i have didnt think about reading them (back when i didnt care about it) and my friend randomly came to work and showed me im like kool i want that
and soooo....
sorry if i copied off you guys (without knowing)
im doing something myself for a change
and soooo....
also... i was looking at those threads... i dont have to move my relay box OR overflow (jeff where did you put your overflow anyways?)
all i REALLY have to do is cut that metal piece which i think im going to be doing after it stops raining a little here
Jeff didnt have ABS I dont think so his overflow is on the pass. side where the ABS pump is on ABS cars.
Not Exactly a cold air intake, but it definitely gives you some bang for your $3.97+ Tax. I'm sure everyone's already thought about this, but I decided to do a little write up on it anyway.
High Flow Intake
________
Bmw 600
________
YAMAHA GX1 HISTORY
High Flow Intake
________
Bmw 600
________
YAMAHA GX1 HISTORY
Whats the point...It's a vg..
lol "NOICE!"
did some more grinding tonight i havent recieved the pics yet... getting WAY close to fitting it properly
I did have an actual question though, Which one is better? A High-Flow intake like 94maxshima put together or a CAI? The high-flow one looks easier to do and has a shorter path for notably thinner air, but a CAI pulls in denser air over a longer path. I want to do one or the other... Opinions?
Grinding it some more
pretty kool sparks coming out of the grill
night time shot of SPARKS!
still need some more grinding to do... it was raining, sun was going down, and getting eatin alive by mosquitoes!!! mann they were out tonight
saturday ill prolly get more done
Originally Posted by MrGone
Yes, BillBrasky and I did, it's similiar to Jeff and my old ones, except VG not VE.
Really...you wouldn't be able to make me one would you? my friend says he's making me one but he's always busy with his business.
Originally Posted by jlars205
That is the point. Not many people really make them
well pretty much all either one does is give you a cool sound. You may get a little power out of the CAI but in my experience I actually lost a little with the under the hood filter (HAI as many will call it) because of the hot air it draws in.
Many on here bought the cheap ebay CAI for an accord or something (search and ye shall find) for the VG. Seems to be cheap and fit OK.
Piggy racing FTL! And apparently it took you guys the entire bottle of my argon to accomplish it.
Does the warpspeed kit place the filter in the fender, or under the headlight section? It says fender, but I'm really not seeing how that works. Reading the instructions it goes:
TB-->tubing-->s-pipe-->tubing-->MAF-->o-ring-->adapter-->tubing-->inlet pipe-->tubing-->filter
It doesn't specificly say WHERE you supposed to cut the hole for the inlet pipe.
Originally Posted by tripleGmax
the directions tell you where to cut and even go as far as to say its best to use a plasma cutter....
From what I've gathered from ppl on the Forums is that, sure, the mandrel piping that replaces the stock piping will allow air to flow smoothly through. However, once it reaches the throttle body in a VG, it'll get disturbed anyway, losing the flow. Sure, it might add a little bit more volume, but is it worth putting $200? for what? like 1HP? I used to want to go that route. I think the only thing I'd do is just a cone filter. No mandrel piping for an NA VG.
I guess the noise would be good? At least it'd sound fast?
Some sort of hijacking, but a question nonetheless:
Anyone know the bolt specifications/attributes for bolts that connect the MAF to the stock aircleaner? I have to pass smog in California, and my CAI has no carb sticker. Slapping the old intake back on but there was sadly no bolts.
oh dont worry... your just hijacking it from the hijackers from the thread starter... lol
i havent been able to do more work on it i just got some other stuff i was installing this weekend ill get some pics of those when im done
BTW that bold on the frame is a bugger to grind through sooo i ground around it and bent it with a hammer lol
the sides are done now i have to grind more of the bottom so i can get my 90 degree in it. after that ill put the full mock up kit in it and see if i can buy the REAL piping and cone filter
and this CAI is for a VE not VG
Dang, Oh well I'm considering this one http://www.warpspeedperformance.com/maxcai.htm as posted by triple G but I'm just wondering...is that K&N cone filter worth the extra bucks or is there something additional for the price being $75 for one and $175 for the other..is the only difference the absence of the cone filter?
