CrankShaft?
it's called a harmonic balancer puller/installer. i'm a little concerned that you're attacking such a job and unaware of the process and tools involved. do you have a shop manual to guide you through?
ya usualy i do car audio, detailing and such iv done some engine work on my 355 LT1 (94 firebird) i didnt know if this was the same it looks alittle different then the harm balancer on my other car.. i got one of those pullers somewhere
Are you pulling the Crank pulley just to be clear? I took one off a Sentra with a 3 jaw pulley puller (2 jaw would have been better) and installed an UDP with a rubber mallet.
BTW is your pulley wobbling?
If you've got a GXE as stated in your profile, you're going to have to pull the timing belt and etc off like Dan said... if you're dead-set on replacing it, go right ahead.. but replace the timing belt and water pump while you're in there.
6spd4dsc
Mar 4, 2016 05:19 PM
hayne
Oct 5, 2015 11:53 AM
they redid the seal but didnt do it right idiots..
