weird putting...
Old Sep 30, 2006 | 02:07 PM
heresmymind
weird putting...
I noticed when I accelerate from a dead stop it sputters badly. and feels like my car is going to stall out. once it rev's up 300 rpms from 700-1000 its smooth again. and almost feels like I get a slight boost of power around 3000rpms. any ideas? It's not injecters all those have been tested. and I checked all vac lines to see if there was a leak but couldnt find one. please help.
Old Sep 30, 2006 | 02:25 PM
Greeny's Avatar
¯\(°_o)/¯
Tune up?....Maf?.....Loose nut behind the steering wheel?
Old Sep 30, 2006 | 02:57 PM
ColombianMax's Avatar
fuel pump??
Old Sep 30, 2006 | 02:59 PM
Greeny's Avatar
¯\(°_o)/¯
Originally Posted by ColombianMax
fuel pump??
Flat tire?
Old Sep 30, 2006 | 03:40 PM
black3rdgen's Avatar
vacuum tubes?
Old Sep 30, 2006 | 03:48 PM
Greeny's Avatar
¯\(°_o)/¯
Originally Posted by black3rdgen
vacuum tubes?
Read much?
Old Sep 30, 2006 | 04:10 PM
lol flat tires... are you trying to say my guess was not an educated one? HUH??
Old Sep 30, 2006 | 04:12 PM
Greeny's Avatar
¯\(°_o)/¯
You said it,not me..
Old Sep 30, 2006 | 05:47 PM
internetautomar's Avatar
mod or sell?
does it matter if its hot or cold (engine temperature)?
Old Oct 1, 2006 | 06:50 AM
heresmymind
ill order a new maf cause its still on its orignal 144k later. Ill have my shop check the fuel pump for me. when i first start it. it runs smooth for about 5 minutes. then the powerloss/puttering happens for the first 500 rpms. grr i cant figure it out...
Old Oct 1, 2006 | 12:21 PM
mod or sell?
check your coolant temperature sensor, it may be sending the "cold" signal instead of the "warmed up" signal which would make the car run rich and like crap too.
$20 CTS > $100+ MAF
Old Oct 1, 2006 | 04:02 PM
elusivemax93's Avatar
maybe by chance a leak in the exhaust system bro check around the headers collector pipe and cat see if u have any erosion or gapping between the connections as i have a slight puttering sound on mine and i found mine to be the front cat gasket
Old Oct 3, 2006 | 06:46 AM
heresmymind
exhaust system checked out. I noticed that my coolent in the holding tank was really dirty with **** floating around in it. so I took it out cleaned the inside good put in 50 50 mixture up to the level that was there and my car ran much smoother. i also checked the tube from the tank to radiator to make sure there weren't any pinchs. car ran great warm and cold for about 3-4 hours then it has a slight put again. and now its dirty once again. So I am going to flush the whole system and try that. thanx for the advice I would of never guessed...
Old Oct 3, 2006 | 07:25 AM
Greeny's Avatar
¯\(°_o)/¯
A dirty coolant system has NOTHING to do with the engine performance,unless it's overheating..It's only purpose is to keep the enigine cool,dirty coolant will still cool the engine,but will eventually rust/rot the cooling system out...
Look elsewhere for the putting/sputtering problem....Or maybe read some of the posts in this thread...
Old Oct 3, 2006 | 08:28 AM
tripleGmax's Avatar
tune up sounds bout right......how old are yer spark plugs and wires?
Old Oct 3, 2006 | 09:59 AM
heresmymind
maybe a year. if that. I just cleaned my engine bay and unhooked and blew off / rewired all the spark plug wires too. how much does a basic tune up cost?
Old Oct 3, 2006 | 10:15 AM
Jeff92se's Avatar
I'm needing a caw
VG + aftermarket cone filter = odd idle and maybe rough running. My guess
Old Oct 3, 2006 | 10:20 AM
Greeny's Avatar
¯\(°_o)/¯
Now that you mention it,i remember a few thread in years past about vg's not liking aftermarket cai filter setups...
Old Oct 3, 2006 | 12:57 PM
You know what, now that you mentioned that you washed your engine bay, I washed my engine once and it was putputting and losing power and it I just adjusted the IACV and it worked fine again..before that the car nearly stalled and everything
AaronL
Nov 15, 2020 11:52 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
05RLS2
Sep 27, 2015 09:24 PM
yamehoo
Sep 24, 2015 10:21 AM
bennuss
Sep 11, 2015 05:55 AM
