Ve Rwd?
Old Oct 4, 2006 | 03:29 PM
PunkFriday's Avatar
Power Dorifto Extraordinaire!
Ve Rwd?
was there ever a RWD trans for the VE30DE engine? i've got a wrecked maxima and a slow AE86 that is begging for 190hp.
Old Oct 4, 2006 | 03:30 PM
maxmaxima91's Avatar
VG AND VE have the same bellhousing, so you could use any year 300zx trans.. dohc or sohc
Old Oct 4, 2006 | 03:31 PM
Jeff92se's Avatar
I'm needing a caw
I think the Z32 rwd tranny bolts up. I "think" being the operative word. But IMHO, the heavy and huge VE30DE isn't really my idea of a good swap motor. Sorry to say but a VQ series would be a much better choice. There might be JDM rwd tranny available. If not a RWD G or Z tranny
Old Oct 4, 2006 | 05:43 PM
Matt93SE's Avatar
STFU n00b!
the Z31 or Z32 tranny will work. it's a VG bellhousing pattern. might have to do some funky work on the flywheel to get a starter to mate, but I'd think you can use a Z32 flywheel and it'll be fine.
Old Oct 4, 2006 | 05:52 PM
internetautomar's Avatar
mod or sell?
Z32 has the same crank bolt pattern as the VE?
Old Oct 4, 2006 | 07:10 PM
Matt93SE's Avatar
STFU n00b!
iirc, yes. both 8 bolt i'm pretty sure.
Old Oct 4, 2006 | 08:24 PM
VEvolution's Avatar
I miss my VE
Is the VE really that heavy compared to good motors for swaps?
Old Oct 4, 2006 | 08:27 PM
JClaw's Avatar
He's right. A 95-99 VQ30DE can be had for 300-400$ in junkyards. He'd end up paying 600-700$ for RWD Z33 6-speed tranny. Both the engine and transmission are bulletproof. Especially in a AE86. Ceramic coated ebay headers can be had for 200$.
It is over 100 lbs heavier than the VQ.
Old Oct 4, 2006 | 09:38 PM
VEvolution's Avatar
I miss my VE
Anybody know if the VQ is lighter then the RB? Probably is, since the RB is cast iron. What about RB lighter then VE? Probably..
Old Oct 4, 2006 | 10:15 PM
Nissan 6's Avatar
Yes it is,,,,,weight of cast iron block > weight of aluminum v6.
Old Oct 5, 2006 | 12:34 AM
maximagician's Avatar
whats that 90's-ish infiniti thats rear wheel w\ a vg? (m-30 or 45?)
Old Oct 5, 2006 | 09:58 AM
Alex_V
J30. Automatic only. I think theres an m30 as well Im not sure.
~Alex
Old Oct 5, 2006 | 11:42 AM
mod or sell?
~Alex
M30 = VG30E RWD
J30 = VG30DE RWD
Old Oct 5, 2006 | 11:52 AM
VEvolution's Avatar
I miss my VE
What about VE?
Old Oct 5, 2006 | 11:54 AM
Greeny's Avatar
¯\(°_o)/¯
What about VE?
The ve also has an iron block...
Old Oct 5, 2006 | 11:57 AM
Jeff92se's Avatar
I'm needing a caw
Doesn't he own one?
Old Oct 5, 2006 | 12:01 PM
Greeny's Avatar
¯\(°_o)/¯
Doesn't he own one?
Old Oct 5, 2006 | 12:11 PM
VEvolution's Avatar
I miss my VE
No, I know that.. How does it compare with the RB in weight?
Doesn't he own one?
Sure do.. And damn proud of it!
Edit: Wow, your really goin all out with those pointers Green
Old Oct 5, 2006 | 12:15 PM
Jeff92se's Avatar
I'm needing a caw
Wait. If nissan 6 just got done stating an IRON block is heavier than a aluminum V6 AND you state you already knew the VE had an iron block.... what's with this question?
What about VE?
Old Oct 5, 2006 | 12:17 PM
VEvolution's Avatar
I miss my VE
Huh? The RB is iron, correct? So is the VE.. Yeah? My question is which is heavier?
Old Oct 5, 2006 | 12:21 PM
Jeff92se's Avatar
I'm needing a caw
The RB is iron. Who in the hell doesn't know that? Your question in no way implies you want a comparison inbetween the VE and RB. Except in your head where imaginary GTOs are bought.
Old Oct 5, 2006 | 12:25 PM
VEvolution's Avatar
I miss my VE
What do you mean? Of course I did.. http://forums.maxima.org/showpost.ph...9&postcount=18 Read carefully next time.. Your making me go crazy here double checkin myself
Heh, whats that suppose to mean? Nobody buys GTOs?
Old Oct 5, 2006 | 12:29 PM
Jeff92se's Avatar
I'm needing a caw
Sorry that's AFTER. How about posting carefully?
Old Oct 5, 2006 | 01:09 PM
BuckFutter's Avatar
play nice children...
Old Oct 5, 2006 | 04:40 PM
Darkwing48's Avatar
I Don't
Old Oct 5, 2006 | 05:41 PM
JClaw's Avatar
The RB26 is an incredibly heavy engine compared to the VQ. Easily 200 lbs more than the V6.
Old Oct 6, 2006 | 04:51 AM
Phoenix's Avatar
Lives in a Maxima
What's it matter? If you can FIND an RB26, then we'll worry about it. As it stand they're completely unobtainable so it's kind of a moot point, isn't it?
Although, I must say, an RB26 in an AE86 would be bad ***.
Old Oct 6, 2006 | 08:20 AM
mtcookson's Avatar
The 350Z tranny is actually considered a relatively weak transmission. The Z32 5-speed is much stronger. If using the VQ you really have no other option though, which kind of bites.
Old Oct 6, 2006 | 06:22 PM
VEvolution's Avatar
I miss my VE
Why don't you look to BEFORE, and you'll notice that I did as well.
The real question at the moment should be.. Is the RB lighter then the VE?
Old Oct 6, 2006 | 07:53 PM
Matt93SE's Avatar
STFU n00b!
it doesn't matter how heavy the RB is.. you're not going to do it anyway.
Old Oct 6, 2006 | 07:58 PM
MrGone's Avatar
O rly? I'm going to do it now to prove you wrong.
oh wait... hmmmm... can I borrow your car?
Old Oct 6, 2006 | 08:02 PM
MrGone's Avatar
No, the real question is can an RB fit in a radio flyer?
No Radio Flyer, No Care!
Old Oct 6, 2006 | 09:28 PM
VEvolution's Avatar
I miss my VE
Going to do what?
If you have to ask......
Old Oct 6, 2006 | 10:23 PM
JClaw's Avatar
5-speed stronger? Based on what?
Absolutely NO reason to believe the gears of the Z32 5-speed are physically any larger than the gears in the Z33 6-speed.
Old Oct 6, 2006 | 11:20 PM
VEvolution's Avatar
I miss my VE
Probably people have blown them already.
Old Oct 7, 2006 | 10:58 AM
Matt93SE's Avatar
STFU n00b!
the 350Z tranny is on something like revision #15, including multiple recalls and warranty extensions on them.... I'd be scurred to put it in a high HP car..
The Z32 tranny has been known to hold up just fine to 600hp cars and heavy track use.
Old Oct 8, 2006 | 08:13 AM
Slamnasty's Avatar
Wouldn't the Z32 5-speed be a little stronger because of the twin turbos? I'd think the tranny would have to be strong enough to take sudden rushes of extra power, as opposed to an NA engine that haas a much smoother progression of power. I dunno, maybe I'm thinking of this the wrong way...
I agree though. The VE rules, but it is truly massive for a V6. It's not a good platform for swapping I think because it's only giving you several dozen more hp, as opposed to potentially over 100 more hp with a VQ, and THEN add in the VQ's extra weight savings, technology, and so on. If you were going to do more of a JDM-style swap, I'd say SR20. As for the VE in a RWD car from the factory, no such thing ever existed, least of all here in the US.
Old Oct 8, 2006 | 08:37 AM
nismology's Avatar
The Z33 tranny is strong, but not all that reliable. And yes, there is a difference...
Old Oct 8, 2006 | 02:06 PM
JClaw's Avatar
If the Z32 tranny is superior to the Z33 trans why is it out of production then? Why didn't they adapt it to the VQ instead of going for a totally different tranny. It's not weight, there has to be a reason. If it aint broke dont fix it.
Old Oct 8, 2006 | 02:11 PM
nismology's Avatar
If the Z32 tranny is superior to the Z33 trans why is it out of production then? Why aren't they still using it instead of the current one? It's not weight, there has to be a reason. If it aint broke dont fix it.
Where did i compare the two tranny's? I was speaking in general terms. Furthermore, Nissan wanted 6 gears.
