Maybe my EGR valve?
Old Nov 17, 2006 | 12:33 PM
heresmymind
Maybe my EGR valve?
I noticed stuttering and tried everything in the book. sea foam. fuel pump pressure. intake leaks. exhaust leeks couldn't find anything. So checked the EGR valve. still pumps up and down. the vacuum tube wasn't clogged up. So after I got the car up when I pressed the throttle slowly and smoothly the valve went up like it should. then when I romped on it from a dead idle the valve didn't move an inch. and the engine bogged down A LOT. Is it not supposed to move when heavy gas is applied? If i leave the car at idle and manual push up the valve from underneith the car rumbles as if to stall out... the same feeling it does when I romp on the gas. could it be stuck? or is it supposed to do this and I am just ? Also I found my engine leaking oil very slightly in 2 spots of my engine. and that makes me sad. Smoke =
Old Nov 17, 2006 | 12:42 PM
redwood_usa's Avatar
egr valve
Does your engine run rough at idle ? if yes then you probably have carbon build up in your egr valve. remove the valve soak the lower end in cleaner and reinstall. You could have trouble if teh valve is stuck open, but it will not affect the engine if its stuck closed. It will however effect your nox emmissions if stuck closed.
Old Nov 17, 2006 | 12:46 PM
heresmymind
it does when i first start it for about 15 seconds... then it idles fine. how do you remove the valve? any write ups around?
Old Nov 17, 2006 | 12:52 PM
Josh's Avatar
I think craig brace has one on his page. But I don't know if that will solve your problem.
Old Nov 17, 2006 | 01:50 PM
heresmymind
so the tube (from the egr valve to exhaust) was completely packed.. I could barely blow threw it. So carbon cleaner and coat hanger did the trick... got it all back and hooked up. the hesitation is still there. Not AS bad. but still there. hopefully now I'll get a little better gas millage too. the 16-18 miles a gallon has been killing me. And I've been taking it easy on her too. So back to the drawing board.
Old Nov 17, 2006 | 01:53 PM
Josh's Avatar
You changed the gasket right?
Old Nov 17, 2006 | 02:02 PM
heresmymind
Gasket was like brand new. literally. and the bolts to the egr were new and came off easy. so i left as is
Old Nov 17, 2006 | 02:24 PM
motionman's Avatar
if you're still getting hesitation, try using fuel additives like stp for your car. it worked for my 92 maxima after a few days.
Old Nov 19, 2006 | 05:55 PM
did you soak the lower end of the egr valve in cleaner too. the roughness is because of carbon buildup on the valve seat. Since your tube was choked up , you can bet that your engine intake valve has carbon buildup too. you need to clean them. easiest way is to remove the hose off the pcv valve and spray air intake cleaner in through the pcv valve at idle.
Old Nov 19, 2006 | 06:52 PM
Greeny's Avatar
¯\(°_o)/¯
I am going to call a bad/leaking injector[s]
Old Nov 19, 2006 | 06:56 PM
heresmymind
alright ill check the Injectors. also ill spray the EGR part too.
shilov
Feb 19, 2024 09:40 PM
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
bumpypickle
Sep 19, 2015 01:07 AM
