Euro headlight pics...INSTALLED!
if you want to see the euro's with an hid set up go ahead and take a look at my car its for sale but here's the thread
http://forums.maxima.org/forumdisplay.php?f=6
check it out
check it out
my max with my hyperwhites in and regular on the right
<a href="http://photobucket.com" target="_blank"><img src="http://i9.photobucket.com/albums/a68/tiggayanigga/0418070857.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i9.photobucket.com/albums/a68/tiggayanigga/0418070856.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
sorry dnt know how to post pictures yet
http://i9.photobucket.com/albums/a68...0418070857.jpg
http://i9.photobucket.com/albums/a68...0418070856.jpg
Originally Posted by bru91
So if they don't look that much better or different than stock does that mean the stock headlights are ricer too? There are light output gains over stock so it's not all show. If you want maximum light output, get E36's but you have to work a little. If you want something that's easy to install with better output than stock but not as good as E36's the euro headlights are worth looking at. So E36 > Euro > stock. It's a matter of whether ease of installation or maximum output are more important to you.
If you want maximum light output (and lowest cost), upgrade the wiring harness (complete with relays) and convert to 9007s. Until I did this, I hated driving my car at night. Now it's awesome! The difference in brightness is incredible.
"I already said that the beam pattern is better than stock. No it's not as great as an E36 projector conversion but it also bolts right in with no modification. The stock beam pattern is extremely crappy. I had a headlight out one time and didn't even know it until i was stopped behind someone and saw my headlight reflection on their car and noticed one was out. So better than stock but not as great as E36's. These are good for people that want better lighting than stock without modifying anything. There's no aiming issues or fitment issues. They fit and aim just like stock. So there that's the final word you can take it or leave it."
so what kind are these called ^? and how much do they cost?
(black housing is available too, i would like to see some one install them with smoked corners)
Custom Enterprise had them $180(but site no longer existant)
EBAY has them $78.00 +$40.00 = $$$$108.00 Shipped !!!
IMO that is spectacular upgrade considering a stock pair is over way over that.(and as BRU91 said , the projection is far greateer than stock, and as i said they look like 4th gen heads) I was looking at one light (due to a lil accident a lucky one indeed) and it was in the 60-80$ range. So i was like screw it I want a hot
pair for the same damn price.
Originally Posted by tigga_tha_don
Euro Clear Headlights 89-94 Nissan Maxima,
IMO that is spectacular upgrade considering a stock pair is over way over that.(and as BRU91 said , the projection is far greateer than stock, and as i said they look like 4th gen heads) I was looking at one light (due to a lil accident a lucky one indeed) and it was in the 60-80$ range. So i was like screw it I want a hot pair for the same damn price.
Nigh pix!
Originally Posted by 2Legal4Me
What does the beam pattern look like at night? how well does it illuminate the road. Becuse there's no rugged edges inside the headlight to portray the light basically it's like having a set of flashlights as headlights.
Nigh pix!
Nigh pix!
Nigh pix!
Nigh pix!
Would buying these be a better deal than just replacing one of the stock headlights? My right headlight is getting moisture buildup inside of it and Im gonna have to replace it or get some new lights and these seem like a good deal and an OK upgrade until I have enough time/money for the e36's. Really it's just how much more would a pair of these cost compared to a single OEM replacement becasue it's my parents money and they don't wanna spend ALOT more.
maybe it's me but it seems as if the pattern is only centering in circular pattern your lows are'nt even lighting up the sides at all. maybe try a 20ft range night pic.
Headlights evolved over the past 16 years, I wish the whoever designed the euro did.
Has anyone tried to change out that smooth euro reflector with a reflector from inside this light:
source: http://cgi.ebay.com/ebaymotors/ws/eB...m=150126950854
The overall shape looks very similar, and looks like it can actually shape the beam. Probably can be merged with slight modification, if any.
Originally Posted by dead2fall
... are they any good?
Does anyone know if the clears have likt a crosshatch on the lens that will cast a better pattern? Or is it just simply clear plastic w/o the crosshatch molded in the lens? I saw this little Mazdaspeed 3 that had little crosshatch nodules designed into the lens to help distribute the light. I just can't believe they'd make clears w/o that.
they are clear glass. these lights are perfect for a bixenon projector retrofit w/ HID. they will keep the smooth curve to the car. be easily aim-able. and very big on the inside making it easy to work with retrofiting. not to mention glass lenses come off very easily in the oven.
clear means it doesn't have anything on the lens.
Yeah, I know that. But what I mean is new cars with clear/projector styled headlights have a tiny (almost microscopic) crosshatch design on the plastic lens cover to better evenly distribute the light that comes from the bulb. pay attention to the headlights in newer cars. better yet, check out the new Mazdaspeed3 and you will see what i mean. I was wondering if the clears for the Maxima had that or if they were just plain and clear with no crosshatch?
As far as I know, the only way to shape light at the cover (after being emitted and reflected) is to use it as a lens, with bulges and shapes that redirect outer light to the inside at a focal point x distance away. Our OE lights do this and make a rectangle shape, it doesnt seem to me that small crosshatches would do that very well.
I maintain an E46 bmw and the covers in front of its lights just have 3 long horizontal lines etched into them, I'm not sure if they serve a purpose, but they are there.
yes the clear euros for use are 100% clear. there are also FLUTED lenses which what our stock ones. and then the LINED lenses that some cars have on them. they dont really help with light distribution but they help with keeping the lights clean and preventing ice and so forth from building up.
-b
-b
Originally Posted by 94maxshima
You have only a few options, none of which consist of a kit.
1989-1992 GXE Rear Reflector Panel:
1989-1992 SE Rear Reflector Panel:
1992-1994 GXE Rear Reflector Panel:
1992-1994 SE Rear Reflector Panel:
The 1992-1994 GXE's and SE's are very similar; though the SE's are "smoked" so it adds a slightly darker effect.
Or You can take it off and fiberglass that section:
Other than that, not really much you can do unless you want to get.... erm.. "Creative"
you were saying you could take the reflector panel off? how would you do that, just grab a flat head screwdriver and pop it off?
Originally Posted by '93maximaGXE
what do you have to do to take the headlights off?
It's easy, "Free Search" ; "Forums.Maxima.org" ; "3rd gen tail light removal"
And if all else fails, go pick up a Haynes Manual, download the FSM, donate the $20 for the good search... or just go LOOK at your car.
what year bmw e36 lights fits? does it matter? and are the e36 the only projector headlights that fit? if not, where can i get them? haha sorry so many questions.
See it now?
Please try to use the search tools provided by this site to help you with redundant questions...
Answers to your question in below links...Also found in the stickies at the top of the page...
http://www.bmwworld.com/models/e36.htm
http://www.angelfire.com/trek/tko/bmw_conversion/
