How to remove governor from your Maxima...
Old Nov 27, 2006 | 04:00 PM
Maxima9750's Avatar
I was bored and messing around with my car (1993 Maxima GXE with the VG30E) and I decided to see if the gas pedal would go down further and make the throttle body move further if I removed the plastic brick from under the pedal. So I had my friend put the pedal to the floor and I wiped off a thin line of dirt on the engine block where the throttle body was at its max position. I then removed the single Phillips Head screw and pulled the brick off. Then I had him put the pedal to the floor again and the throttle body actually moved slightly further this time (probably about 2mm). I then took it out on the road to experience the difference. It is hardly noticeable when going slow but if you are on the express way and gun it, it seems to make a much bigger difference. It makes a significant difference in the car's top end speed. My mom has a 2003 Maxima GLE which has one of these too and it's the same thing. The only thing I don't like is that it doesn't give a thud that is as satisfying when you slam the gas as it did before. I am wondering why Nissan put it there in the first place. The car runs just fine when floored with this and doesn't make any different noises and still shifts at about 5800-5900 RPM (yes, I have an automatic unfortunately). I don't know if the VE30DE engines have this but you should look to see if you have one. It's a pretty sweet find since it gives you more power and doesn't cost a dime.
Old Nov 27, 2006 | 04:20 PM
goon9's Avatar
U sure you just didn't have slack in your cable????
That lil block is the prevent you from strtching your cable.
I'm pretty sure it's a 'Block Thing' not a governor.
Old Nov 27, 2006 | 04:21 PM
Greeny's Avatar
¯\(°_o)/¯
Maximas are not governed...
You need to recalibrate you're @ss dyno...
Old Nov 27, 2006 | 04:22 PM
VEvolution's Avatar
I miss my VE
I don't know if removing that was the best plan. I heard you shouldn't for some strange reason, just don't know what that reason is. But I heard it's there for a reason and the idea that your getting better top end may all just be in your head.
Edit: Well yeah, what they said..
Old Nov 27, 2006 | 04:24 PM
goon9's Avatar
It is there to prevent you from strecthing your cable!!!
If your cable is proporly tightened your TB will be wide open all the way when it hits the brick. And there shouldn't be any slack in the cable.
Old Nov 27, 2006 | 04:32 PM
Jeff92se's Avatar
I'm needing a caw
Anyone predict the next thread? I'm on the freeway and stranded! Stupid throttle cable broke!
Old Nov 27, 2006 | 04:34 PM
Greeny's Avatar
¯\(°_o)/¯
Old Nov 27, 2006 | 04:48 PM
rimaximaman's Avatar
Help, I stranded with a Broken Throttle Cable ........That is so Funny!!!
Old Nov 27, 2006 | 06:12 PM
SEmy2K2go's Avatar
Go BUCKS!!!
3 threads? really?
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
