Timing Chain vs. Belt
Old Dec 3, 2006 | 07:06 PM
maxitech's Avatar
I just had a random question pop into my head while doing some homework on chain drive systems. On a VG (my car) there is a belt and hence no need for lubrication. So I was wondering what kind of lubrication system is used on the VE's timing chain setup? Curiosity is what makes this forum go 'round!
Old Dec 3, 2006 | 07:10 PM
AlpineGt66's Avatar
engine oil?
Old Dec 3, 2006 | 07:11 PM
Greeny's Avatar
¯\(°_o)/¯
The engine oil pump sends oil up through oil gallies in the block/heads to the chains....
Old Dec 3, 2006 | 08:27 PM
maxitech's Avatar
So it is exclusively a type of oil stream lubrication with some kind of syphon/drain mechanism at the bottom...There is not a bath of oil that the lower sprocket and chain sit in, correct?
Nevermind, I just found a Table to determine which lubrication system is suggested and considering the rpm's the gears can turn at, oil stream lubrication is the only type that would work. I guess I was just wondering if the crank gear sat in a bath of oil, as well...
Old Dec 3, 2006 | 08:37 PM
maxitech's Avatar
Originally Posted by AlpineGt66
engine oil?
Thank you Mr. Wizard...
j/k
Hondarydr
Dec 30, 2024 06:15 PM
tsi6001
Oct 3, 2022 10:23 PM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
maxinout93
Oct 27, 2015 01:29 PM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
