91 SE hard two Shift
Old Jul 2, 2001 | 08:42 AM
Kraus91SE's Avatar
Has anyone had a problem shifting? Sometimes I have to force my car into gear. Do I need a new tranny or will a new clutch and release bearing fix the problem.
Old Jul 2, 2001 | 09:02 AM
«§»Craig B«§»'s Avatar
first thing to check is the clutch fluid under the hood right next to the brake fluid
hopefully this is your problem, if not, it could a number of different things including those that you said, but it's hard to diagnose over the computer
Old Jul 2, 2001 | 09:20 AM
TerribleTed
two = second gear?
The Subject said Two shift as in the number 2. I will assume that means you are having troulble shifting into second gear.. if that is the case I would change the actual tranny fluid (use Redline MTL) before I would touch the Clutch fluid. If that doesn't help then your 2nd gear synchro is most likely toast. I would refrain from downshifting into second from here on out.
If it is a clutch problem you would feel this in all gears not just second. It is at that point I would bleed the clutch master cylinder. keeping in mind that the clutch is self adjusting, your friction disk may be worn out, so it may be time for a total clutch job.
Old Jul 2, 2001 | 09:31 AM
Kraus91SE's Avatar
Thanks for the help, and it's in all gears. I ment too not two.
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
fx4five
Oct 1, 2015 04:58 AM
