fast help!!!!!timing belt
Old Jan 19, 2007 | 12:26 PM
4thgradedropout's Avatar
ok so it turns out it is not my starter my timing belt blew or something mechanic wants 700 to fix 6 hours of labor....a timing belt cost 16 dollars so my dad is going to do it....we do not have a manual. does anyone have a write up on how to do this? please get back to me asap......
Old Jan 19, 2007 | 12:33 PM
Alex_V
you have to be careful about that, because if your timing belt died you could have at least 1-2 bent vavles. My friends 300zx (same engine) bent all 6 intake valvles and broke one.
if that 6hrs labor includes checking the valves and replacing if nessicary then your good to go.
~Alex
Old Jan 19, 2007 | 12:35 PM
700 dollars is just to do the timing belt that is why we were going to do it our selves my dad has done it many of times on our z cars we used to collect so that is why i was needing a good write up on how to do it
Old Jan 19, 2007 | 12:36 PM
PLUMMAXSE's Avatar
By all means, buy a haynes manual or similiar for replacing the timing belt. The timing of the cam and crankshaft must be set properly. Manual will explain everything. You are already saving $700. Spend some on a manual
Old Jan 19, 2007 | 12:38 PM
bvtran's Avatar
94c Big Max
get a Nissan FSM it's way better and more accurate than Haynes for this type of advanced works.
Old Jan 19, 2007 | 12:50 PM
where can you get one?
Old Jan 19, 2007 | 01:04 PM
internetautomar's Avatar
mod or sell?
of your timing belt snapped, just get a JY motor.
replace the timing belt and seals on it, and install that.
if the timing belt snapped there is a very high chance that you will need to replace multiple valves and possibly pistons and other parts.
you will definately need to pull the head though to make sure.
Old Jan 19, 2007 | 01:12 PM
the car was in park when it happened i went to school it drove fine came out and the it won't start the belt on the side keeps spinning but it does not start
Old Jan 19, 2007 | 01:27 PM
is this job even worth it? my only problem is i have no one to co-sign me for a new car and im 19
Old Jan 19, 2007 | 01:41 PM
bvtran's Avatar
94c Big Max
you can get 92 FSM on ebay. They don't have bootleg electronic version available yet. Only for 94 up to 2005.
+1 for Brian suggestion, for $700 you might as well spending $600 on a new JDM engine with no more than 60K at max. It comes with everything attached to the engine except for tranny, e.g. water pump, alternator, etc... I really think it's way better to get a JDM than to overhaul your engine apart so you guys could manually adjust the pistons, cam, etc... It's not easy works, chances are it'll get screw up again. Even the pros make mistakes too. Save your headache man.
Old Jan 19, 2007 | 01:50 PM
after i do this and get it running im selling it i have already replaced all6 injectors all 4 struts front control arms and bushings passenger cv shaft fuel lines i have an oil and a radiator leak so yea
Old Jan 19, 2007 | 02:12 PM
Greeny's Avatar
¯\(°_o)/¯
You now have a 500 lb paper weight...
If you break a timing belt on these cars,it will bend Every valve,Every time..IMO,trying to repair this engine is not something a novice shadetree mechanic should mess with..The damage may be more than just the valves,i have seen cracked pistons due to the valves hitting them hard enough..
Just replace the engine...
Old Jan 19, 2007 | 02:44 PM
my dad is a certified mechanic in every thing from cars to planes he has is amp license and one for everything else and owned his own mechanic shop out of our garage for like 20 years... he has done this many many times just never on a maxima...
Old Jan 19, 2007 | 02:45 PM
the belt is only 16 dollars and if more is broke then im going to say F**** it and just part it out and buy a new car and make the payments....
Old Jan 19, 2007 | 02:51 PM
Greeny's Avatar
¯\(°_o)/¯
IMO,replacing the engine is easier than repairing the damage done from the broken belt...
Especially time wise..
Old Jan 19, 2007 | 04:19 PM
rimaximaman's Avatar
Yup time for a new engine!!!
Old Jan 19, 2007 | 04:25 PM
mtcookson's Avatar
The 94 e-FSM will cover the earlier Maximas engine wise. It has info for both the VG and VE and changing the timing belt on the VG is the same on pretty much every VG.
Hey now, the VG weighs less than 400 lbs. It was the lightest V6 at the time it was made.
Old Jan 19, 2007 | 04:32 PM
Greeny's Avatar
¯\(°_o)/¯
With all accessories attached?
Meh,close enough..
Old Jan 19, 2007 | 06:06 PM
mtcookson's Avatar
The accessories aren't bad though...
I'm not sure if it includes the accessories or not. I know the 84 VG30ET was weighed in at 396 lbs. but I don't know exactly what was all on it. I'm sure the turbo stuff was on there at the very least so ours might be a tiny bit less.
Old Jan 19, 2007 | 06:25 PM
mrkanda's Avatar
Taking my Maxima to the Max!
Hey, we should just let the guy change his own timing belt and see if that does something. I changed mine a few years ago by myself, and I have never done it before. I didn't even have an FSM, only the Haynes manual. So, go to it and see what else needs to be done after that. If it doesn't fix it then you have a great excuse to upgrade the internals or swap in a low mileage engine. Good Luck!
-Mark
Old Jan 20, 2007 | 08:59 PM
it is a 17 dollar gamble so if it does not work i have nothing to really loose and like i said my dad is doing it and he has done it many of times i am just hoping nothing else is wrong but it did come of while it was in park
Old Jan 20, 2007 | 10:16 PM
mod or sell?
it's only a gamble if you have a chance of winning.
if the belt snapped, you bent valves.
You lost, now pay up
Old Jan 20, 2007 | 10:39 PM
Hectic's Avatar
if you need a timing belt, i still have the one the car came with that i replaced before it needed it. it probably only has 30k miles on it. you can at least check your compression afterwards..
Old Jan 20, 2007 | 10:53 PM
todamax's Avatar
There is no chance there isn't internal engine damage.
Old Jan 21, 2007 | 02:24 PM
my dad is taking it appart as i type this the belt did not snap, looks like the teath on the belt just wore out and it was just spinning but not catching on the pullys so so far so good my water pump is bad though but i figured that
Old Jan 21, 2007 | 02:31 PM
todamax's Avatar
Then its pretty much the same as a broken belt. If you move more then a couple of teeth, valves are done. If you must, before you buy a new water pump put a new belt on and do a compression check. But I still think that is a waste of time... Get a junk yard motor, they will be cheap.
Old Jan 21, 2007 | 02:49 PM
has anyone ever done this and had it work? this is really my only shot i have no money to get a new car and no time at all to swap an engine
Old Jan 21, 2007 | 02:51 PM
Grace_Imports's Avatar
It's unlikely, but if you do not wind up with bent valves get a new tensioner otherwise it will turn around and bite you. The other guys already mentioned the seals and water pump. If your dad is a cert mech then he should know that tho.
Old Jan 23, 2007 | 08:58 PM
todamax's Avatar
hey, any news?
tsi6001
Oct 3, 2022 10:23 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
yat70458
Aug 3, 2015 01:16 PM
