strange things happening-HELP
Old Jul 5, 2001 | 07:13 AM
Dawns Maxima
I have a 93 Maxima with over 103,000 miles. I say over because ever since i bought it 6 years ago the odometer does not always work. First 1. When I go to start my car it will turn over and try to start but it usually takes about 4 times before it starts when it does its like the fuel is not getting right to it.-strange it doesnt always do this-sometimes it starts first time. alittle after my car started doing this it really started getting strange-sometimes my keyless entry wont work -therefor the electric locks wont work-my right turn signal sometimes wont work- Could all of this be some kind of computer chip? The guy that works on my car changed the fuel filter and adjusted the timing-did not help at all. Please help.. My mechanic said just keep going until it stops and wont start.. I am looking for a new mechanic!!
Old Jul 5, 2001 | 08:17 PM
efarhat's Avatar
I'm having the same problem with my Max. Sometimes it'll start up without a problem and other times it will start and shut off immediately. Someone said the Idle is set to low but I don't think that's it. If you hear something, please let me know.
I too changed the fuel filter. Could be the fuel pump?? don't know.
Old Jul 5, 2001 | 08:45 PM
Cincy94Max's Avatar
How about checking the distributor, rotor, ignition wires, spark plugs. My car is due for all of these to be changed and it takes a little while to turn over.
Old Jul 5, 2001 | 09:04 PM
atulb84's Avatar
this may be a stupid question....but can you change your own fuel filter and if you can...what kind do i need and how hard is it to do? thanks
Old Jul 6, 2001 | 08:03 AM
Steindawg
Yes you can, its actually pretty easy because the filter is so simple to get to. Basically all you need is the new filter, there is a specific procedure you have to follow with pulling fuses etc, I think this depends on exactly which year and type you have. Check your chiltons, it tells you exactly what has to be done, or e-mail me your info and I will fax the relevant pages to you. CS
tarun900
19
Dec 20, 2021 06:57 PM
doctorpullit
Mar 29, 2016 11:08 AM
bigfrank
Oct 1, 2015 12:51 PM
09maxshawn11
Sep 30, 2015 10:28 AM
