tailight rewire
Old Jul 5, 2001 | 02:51 PM
Scrizza Delph's Avatar
I just checked out maxima how to's & saw the tailight rewire so I gave it a shot. is the way its explained here right? http://216.218.233.126/blake/howtos.html it says to switch the top bulbs, what difference does that make they look the same. shouldn't I be swtiching the outer ones instead? wtf, the cover wont go back on either 10min my azz yo, a little help for the newbie?
Old Jul 5, 2001 | 05:26 PM
lcali1's Avatar
U switch the top brake bulb wire with the turn signal wire. Switch em out. Your done.
Old Jul 5, 2001 | 08:45 PM
atulb84's Avatar
the site said 10 to 30 min....not just ten
Old Jul 6, 2001 | 08:49 AM
djslinkyz's Avatar
i tried doing this, but the green wire for the left turn blinker is too short to reach the other bulb's spot. (the other side was fine) i tried to see if i could add a longer wire to the end of it but couldn't see how i would do that, so could i cut the wire in the middle, and add more in between and then just tape it up with electrical tape or something?
Old Jul 6, 2001 | 10:35 AM
«§»Craig B«§»'s Avatar
that would work fine, soldering the connection would be better though just to make sure its a solid connection and isn't gonna come apart. If it did come apart, it could lose power to your outer brake light or ground itself on some metal and blow a fuse; not a big deal, but a little bit of a pain.
wire nuts would work well too if you're not into soldering stuff
also, anyone else notice how similar Blake's site is to mine? I just find it odd that he has some of the same pics on there. Oh well
Old Jul 6, 2001 | 12:21 PM
C-Dawg's Avatar
I smell an azz whuppin' in the making.
Old Jul 6, 2001 | 02:06 PM
Re: .
g & white or g & yellow?
Old Jul 6, 2001 | 07:21 PM
djslinkyz's Avatar
what kind of wire should i use?
Old Jul 8, 2001 | 08:09 PM
djslinkyz's Avatar
also, is this legal in texas? i read on some website that has the rewire that it might not be legal in all states. i'd refer to my texas drivers handbook but i threw that out a long time ago
Sir Tilus
Mar 22, 2016 01:49 PM
griffins98max
Aug 30, 2015 10:23 PM
Dman1989
Aug 27, 2015 09:10 AM
Blackwind
Aug 5, 2015 06:35 PM
