91 GXE Supercharger options
Unfortunately, there aren't any forced induction kits made for our cars. A turbo application can be done, but it requires some modification to get the turbo to fit, and if you have an auto, it would go boom.
Originally Posted by Dhunterx
....and if you have an auto, it would go boom.
Not necessarily, bro. Just a matter of PROPER application. I could go into detail over this, but it's late and my wife wants me to "keep her warm".
The Nissan 3.3 liter came with a supercharger, the VG33ES. It was available in the Pathfinder, Xterra, and Frontier. To supercharge the VG30E you have to change the heads to the VG33 heads (involves a little head work to make the coolant holes line up..1/8") and modify your hood. The blower won't fit under a factory 3rd gen hood. then there is the usual ECU mods. It is probably easier to get a VG33ES engine from a Nissan truck and do the swap. But with only 210hp is it worth it?
hate to bust you guys bubble! but on the z31's most of those guys are running just the 3.3 plentium and look they cant even get hood closed. So makes you guys think that that supercharger will work and close the hood fully
Why a Z31 engine? Theres no difference worth a swap. And the VG30ET has crap for compression and is expensive.
Just get turbo z31 manifolds, a T3 and tune your stock ecu with 370cc injectors. Or hire a welder (or maxmaxima91) and make some custom stuff.
A VG33ER wont fit because it wont clear the hood, and that super charger is undersized any way.
~Alex
~Alex
oil fiter clearance was an issue i just swapped out to avoid all that
but its still not an easy task i found out the hard way
and yes hiring a welder or a fabricator will indeed speed things up
better have a phat wallet
Originally Posted by dafiremaster
ok then heres another question. If supercharging requires heads and what not, or a different engine. Whats a good turbocharger to go with?
Actually, I've been wondering. Where the HELL do you buy a Gloria motor at? I'd rather have that for a project than just a Z31 motor.
A good turbo to go with, in my opinion, would be the T3/T04E 50 trim w/ .63 a/r turbine. The compressor map matches very well with the VG up to about 23 psi or so, which is nearly 450 hp or more. If you're wanting to get a real nice turbo, the GT3076R would be a good match as well... but you're looking at about $1,200+ for the turbo alone. For the standard T3/T04E, you can pick that up for $619 here http://cheapturbo.stores.yahoo.net/gat350trw63a.html and might even be able to find one cheaper on ebay. If you go with that cheap turbo site though you know you'll be getting a fresh, true Garrett turbo.
If you want to go absolutely crazy, the Holset HX35 is a good fit. That turbo will support nearly 600 hp... you'll definitely have to put a good deal of money into the tranny to get it to support that though. I think having an auto though, you'll have much better luck getting it built to handle the power than the manual trannies but you most definitely have to get it built to handle it.
Originally Posted by maxmaxima91
the oil filter is in the same spot on our cars as a z31.. so long as you unbolt the maxima oil filter relocation unit... and buy a z31 oil filter stud.... piece of cake..
there is a engine place in california called K.Watanabe goole that to get the information it's in lynwood, ca
also there is Gspeed in gardena, ca too there pretty good also.
You don't need to worry about all that.The stock VG30E compression is 9:1, perfect for boost. Up to about 400WHP you don't have to touch a thing. After that I'd still be worried about the transmission crapping out. Like I said before you don't need to worry about swapping engines until your making some serious power.
~Alex
~Alex
when i build an engine for my car... it going to still be 9:1 compression.. 9:1 is already pretty low. 8.3:1 is just to low.
but before i build an engine.. ima try really hard to hit 500 whp on the completely stock engine.
Derr... I forgot about the VQ. You have it right.
The Maxima's engine bay is bigger than the Q45's so it would fit if it were rear wheel drive... though, if it were rwd the engine bay would likely be much smaller, though not small enough for the VH not to fit. Ehh, I'll stop there.
tarun900
19
Dec 20, 2021 06:57 PM
Apr 16, 2020 05:15 AM
