A/C removal
Old May 22, 2007 | 08:02 PM
Maximahappy22's Avatar
A/C removal
I stopped using a/c in my track car (VE) and removed the belt to free up some ponies, my question is how hard is it to completely remove the a/c compressor from the engine to save some weight.
1.what is involved?
2.is it difficult?
3.any special tools needed?
4.any health precautions?
Thanks.
Alex
Old May 22, 2007 | 09:26 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
while you're at it are you going to rip out all the other climate control-related items too? some of them are heavy enough to make their removal worthwile.
Old May 22, 2007 | 10:05 PM
no i still want the car to be somewhat comfortable and street ready, a/c in Washington is not a necessity, especially for a track car...
I still want the heat and blower controls... i just want to know how to take the compressor out.
Old May 22, 2007 | 10:16 PM
Alex_V
Compressor isn't a problem. Just make sure you get the system discharged at a shop, the refrigerant in them is very bad for the environment. After thats out take out the radiator, the AC condenser in front of it, all the lines, and thats about it. Should be about 30-40lb's lighter.
~Alex
Old May 22, 2007 | 10:20 PM
thanks ill look into that.
Do i have to take the radiator out?
Old May 22, 2007 | 11:26 PM
Alex_V
I'm pretty sure you can just unbolt it from the car and leave all the coolant in.
~Alex
Old May 23, 2007 | 08:16 AM
DanNY's Avatar
Ad·min·is·tra·tor
if you want to take it to the next level then might as well yank out the evaporator too while you're at it.
the rec/drier will come out too w/ the condensor...but make sure you have a shop pull the R12 out.
Old May 23, 2007 | 08:39 AM
Greeny's Avatar
¯\(°_o)/¯
+1 on a shop doing the r12 reclaim..some shops will not charge you to do it due to the cost of r12..
Old May 23, 2007 | 08:41 AM
mikekantor's Avatar
When I was diagnosing some AC problems a while ago I went to Jiffy Lube and they drained and later put back the coolant for free, so there is an option for you.
Once you are ready to remove the compressor, the first step is to remove the alternator. This will give you access to the bottom two bolts holding it. With all the hoses, belt, and harness removed, hold it so it doesn’t fall down and undo the two bolts holding it at the top. Don’t undo the ones going into the engine, but the ones perpendicular to them. I think they are all 13mm.
To free up a tiny bit more weight you can also get rid of the belt tensioner.
Old May 23, 2007 | 05:46 PM
ok ill take it to a shop and see what they say when baseball is over, thanks for the replies.
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
