9007 bulb upgrade**With Pics**
Originally Posted by MyGreenMax94
Thank you michael for your addition to this thread,,
Would going to 9007 from 9004 benefit at all with HIDs? I have the ebay "Euro" headlights, with 6K HIDs. The beam pattern with these lights isn't the greatest. It looks alot like the pic in that Euro Headlight thread with the "two pies on the wall". Just curous if 9007 HID bulbs will disperse the light alittle better.
Originally Posted by VEvolution
Yeah, good question
Good answer..http://forums.maxima.org/showpost.ph...9&postcount=37
Did the swap today, helped out quite nicely for the $18 and about an hour labor doing things nicely.
Had to re-aim them from the 9004 aim though. I got in my dads truck and parked the max down the street and drove towards it and it blinded me horribly. But I'm all good to go now
If you absolutely must cut the wires (and I wouldn't, switching the pins around in the connector is a much better solution) don't rely on electrical tape for protection. Cover those connections with heat shrink tubing, then wrap the harness with the electrical tape.
Yes,switching out the wires is the best way to do this mod,..[i didn't know they were accessible
]but if you choose to cut the wires,soldering the connections will work fine,a quality brand electrical tape[3M],will protect the wires connections for many years..
one thing that some others and i did was rotate the bulb around in the housing to give a better beam pattern and then switch the high and low beam wires. that gives a 65w "low" beam and 55w "high" beam. better beam pattern too. iirc, stock harness is rated up to 65w, so it can handle it no prob. i've had mine done for a few years. i can't really remember what i did though, but i'm sure you can search for it. one of the better/cheaper mods for a terrible oem headlight. i almost think it is better than a bimmer conversion--might not look as good though.
9007
9004
9004
Originally Posted by Gunther
I don't know what your talking about before there, but the upgrade to 9007 is a huge improvement over the 9004, so if you're looking for better light output throwing the 9007's in is the way to go.
as for the other thing, i was asking if our beam pattern is supposed to focus almost all of the light in the middle, as opposed to my mom's car, which has flat even light and upsweeps to the right at the cutoff. She has a 99 Camry, if it matters.
going to start on this mod in about 15 minutes. i'll let you know how smoothly it goes. i'm planning to grind the housing rather than the light. but i may change my mind once i'm out there.
ok well it's all done now. i had a bit of trouble finding the right place to grind the bulbs. I decided not to touch the housings, rather to grind the bulbs like greeny. I have a submission for the writeup
take a thin strip of paper or something, half an inch wide and long enough to wrap around the notched section of the 9004 bulb. take a marker, and mark each groove in the 9004 light, and make sure to cross-mark the top notch (a + sign) to indicate that you will line it up there on the 9007 bulb. Now take that paper and wrap it around the 9007 bulb and line up the top notch, and take a centerpunch and make a small mark through the marked notches from the 9004 into the plastic of the 9007, so you'll know where to start grinding exactly. Do the same thing on your other 9007 bulb, and now you will grind in exactly the right spot, without wasting time test-fitting and adjusting and eyeballing and etc etc like I had to.
I'll get a road test tomorrow morning, at the latest. I go into work at 5am so it'll still be very dark out.
http://s164.photobucket.com/albums/u...daver/9007XVs/ here it is. night pics.
and a video http://s164.photobucket.com/albums/u...MVI_0134_3.flv
i need this swap done seriousle one head light is out ans socket for some reason got destroyed went to my local pep boys but they dont have any 9007 sockets can anyone sell me the sockets please need asap
I killed/melted a harness with 80/100 bulbs way back in "tha day". If you get by without meltage you are lucky.
Michael you have lovely thumb prints btw.
Duckman, I have the Euros too. Your 9004/9007 HID question if using the euros is a good question. My guess is you'll have a more intense pancakes lol. But seriously, even if there was an improvement, I doubt it would justify shelling out more $ for.
.... this swap is no sort of repair to need done.. it's not like using 9004s, which the car was built with, will harm it an any way at all. Advance auto parts has 9004/9007 headlight plugs and shrinkwrap tubing so you can set up your wiring nicely.
capedcadaver: your headlights may be aimed a little low... hard to tell from that vid, but it seemed like they didnt really illuminate much down the road. especially the righthand (passenger side) one
i really need to aim them outward as well. they cross paths or come darn close to it, about 30 feet out.
Will the beams need to be aimed up or down from their stock position?
Also, can anybody recommend a good brand of bulb to purchase? And will anything from 3000k - 12000k work?
I heard Wagner makes some great bulbs. Although I have Walmart cheepies in right now and they're still a world of difference form the 9004. I would suggest buying bulbs online. Also... you will most likely have to aim the headlight down some.
Sylvania Xtravisions are a solid choice. Bright and at a good price. If you want bright and white light, then the Sylvania Silverstars.
got 2 more videos. pleeeease excuse the fact that i my voice, when recorded, sounds like Richard Simmons
. I just have a stuffy nose like 24/7.
Here're my additions to the comparison shots:
e36's win for sure, but for how easy the 9007 conversion is there's no reason not to do it if you're not gonna pay for new headlights.
The 9004 demo'd is a Sylvania XV/2 (55/65), the 9007 is a Sylvania CB/2 (45/65), the e36 high are phillips I think, don't remember the lows at all. If anyone really cares I can check.
9007 is the 55/65... and i CBs are garbage. light washes out unless you have alot of it, and CBs do not (that's what silverstars are for). I use Sylvania 9007XVs and it's white enough for me.
did more aiming today, i'll let you know how it looks after tomorrow. aimed the right one up, aimed both out. it looks dumb with not being as flush as before but whateeeever. function before form.
Better than the pictures show even.
I run Xtravisions, personally. $20/pr. I was just saying that if you want the blue-coated bulbs, you really need silverstars to augment output... just that I don't totally recommend them, due to their cost and lack of color compatibility with my city's street lights.
I must have missed that order
