Rear parallel link bushings
Old Jun 6, 2007 | 05:59 AM
redwood_usa's Avatar
Do I need to drop the rear crossmember to replace the bushings or does the long bolt slip out under the crossmember?
Old Jun 6, 2007 | 06:00 AM
maxitech's Avatar
If you are doing the inner bushings then yes, you need to drop the crossmember...It's not too hard, just 5 bolts.
Old Jun 7, 2007 | 09:08 PM
maxitech's Avatar
Did you get the job done? Hopefully you replaced the rubber bushings with polyuretane pieces.
Old Jun 8, 2007 | 06:10 AM
I'm going to do it this weekend. Yes, poly from courtsey nissan. Since I am using poly, can I torque the bolts before I lower the car, or do I still have to put the wheels down and then torque.
Old Jun 8, 2007 | 06:32 AM
Michael's Avatar
Back in a 3rd Gen.
with poly you can torque it while its still in the air. With rubber bushings you have to have the car down because there is no give to the rubber bushing and you can tear it if you torque it while its in the air and then set it down.
With Poly the bushings move freely and it doesnt matter when you torque it because you will not tear it.
Matt93SE
May 24, 2019 02:58 PM
AcuraLegend
Oct 17, 2016 08:47 PM
Huttig2009
Sep 25, 2015 03:31 PM
AcuraLegend
Sep 22, 2015 04:22 PM
