help::temperature gauge inside is going out
Old Jun 12, 2007 | 10:51 PM
mofoaka's Avatar
is there an DIY how to fix the temperature gauge? when i hit the dashboard needle will either go all the way up.. or normal.. or just look dead.. coudl it be a bad solder? HELP PLEASE =)
Old Jun 12, 2007 | 11:02 PM
puna2k's Avatar
mine flops like a fish when I hit a bump, I think mines got something loose, you might too
Old Jun 12, 2007 | 11:07 PM
Jeff92se's Avatar
I'm needing a caw
Check the single black wired connector at the coolant temp sensor. Could be loose.
Old Jun 13, 2007 | 04:56 AM
cheatham's Avatar
I need a brake.
There are causes for this that aren't cluster related. In my case, changing out the cluster solved my problem. The old one probably just needed some solder, but they are only about $10 at the boneyard so I took the easy way out.
Old Jun 13, 2007 | 06:12 AM
Prophecy99's Avatar
hehe....mine has been like that for a year...it works and dosent, mine turns off/on when i switch gears....but for the majority of the time stays on..if it completely is stayin off fix it, but if it is only once in a blue moon you mite be ok IMO
Old Jun 13, 2007 | 10:39 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
http://forums.maxima.org/showthread.php?t=522594 i had a similar problem. Opening up the throttle caused enough vibration from the engine to wiggle the connector's metal tab loose... which meant it contacted at times but not at others. I went to a JY, got another temp sender, problem solved.
for VG owners with this problem (unless the VE part is the same as well): if possible pull one of an '89. The design is more durable IMO, than the one that was OE on my '90.
Old Jun 13, 2007 | 11:42 AM
Jon94SE's Avatar
Mine started to do this as well recently. Mine will just drop all the way down. I think it's an air bubble though because it seems to change with elevation. I live at sea level and when ever I drive out to my grandparents house it's like it drops at the same spot every time I go there.
Old Jun 13, 2007 | 11:55 PM
mofoaka's Avatar
mine is definitely gauge related and not due to the sensor on the engine.. is there anyway i can fix the solders on the gauge itself? is there a how to?
Old Jun 17, 2007 | 06:37 PM
Max_5gen's Avatar
Most likely it's the contact from wiring to the coolant sensor itself: when I had this trouble I tried to disconnect the socket and the wire broke off. No, I didn't pull the wire, it was just corroded that bad. I haven't replaced the connector yet - just cleaned the end of the wire and placed it in the little hole in the middle of the sensor plate. I don't recommend to do it as a permamnent fix of course.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
RWCreative
Sep 21, 2015 11:01 AM
