fule pressure regulater hose
Old Jun 17, 2007 | 10:02 PM
mooze's Avatar
does anyone no if this line would cause my car to cut out if it was not run to the right spot?
Old Jun 17, 2007 | 10:49 PM
LvR's Avatar
LvR
Yes it will.
Old Jun 18, 2007 | 06:46 AM
mooze's Avatar
so where does it go exactly
Old Jun 18, 2007 | 07:21 AM
Greeny's Avatar
¯\(°_o)/¯
Old Jun 18, 2007 | 09:04 AM
mooze's Avatar
Originally Posted by MyGreenMax94
great pix but not right hose. thats the fuel filter. i need the regulator located in on the left of the tb (saying your looking across engine from divers side)
Old Jun 18, 2007 | 09:11 AM
mooze's Avatar
Old Jun 18, 2007 | 09:13 AM
Greeny's Avatar
¯\(°_o)/¯
Old Jun 18, 2007 | 09:16 AM
mooze's Avatar
yeah so its going to the end of the vacuum gallery correct?
Old Jun 18, 2007 | 09:32 AM
Greeny's Avatar
¯\(°_o)/¯
Old Jun 18, 2007 | 09:35 AM
mooze's Avatar
this is the hose behind the plenum i have it run to the vacuum gallery line that connects to the fuel pressure regulator hose. the vaccum gallery is those goldish lines that run behind the throttle body
Old Jun 18, 2007 | 09:36 AM
mooze's Avatar
is that correct
Old Jun 18, 2007 | 09:39 AM
Greeny's Avatar
¯\(°_o)/¯
Old Jun 18, 2007 | 09:42 AM
mooze's Avatar
i have an auto tranny.
Old Jun 18, 2007 | 09:44 AM
mooze's Avatar
i guess just eliminate the hose to the surge tank and that'll b it. ok.
Old Jun 18, 2007 | 11:12 AM
92 Max's Avatar
On my 92 SE 5spd the fuel pressure regulator vacuum hose connects to the nipple with the gold tag that says don't remove when engine is hot or words to that effect.
Old Jun 18, 2007 | 12:07 PM
mooze's Avatar
got any pix?
Old Jun 18, 2007 | 12:17 PM
mooze's Avatar
http://s6.photobucket.com/albums/y21...=VIDEO_023.flv
in this video you can see were it begins to start skipping and shaking and so4th.
Old Jun 18, 2007 | 12:28 PM
Greeny's Avatar
¯\(°_o)/¯
That thing sounds terrrible dude!!!
Sounds like it's only running on 2 cylinders/w a bunch of crap hooked up wrong...
Where do you live in georgia?
For the right price i can come down and help you out maybe?
Old Jun 18, 2007 | 12:40 PM
mikekantor's Avatar
It started and held idle somewhat, so not all is lost. Try to take some good photos of your hoses and then we can tell you what is hooked up wrong.
Old Jun 18, 2007 | 12:42 PM
mooze's Avatar
not in georgia right now. supposed to go back in two weeks but at this rate doesnt look to good. im in sc. i no i have one bad coil as it was cracked at the stem (rear coil) i have to check the other two. ive been looking for replacements.
Old Jun 18, 2007 | 12:53 PM
mikekantor's Avatar
And then check the other 3 coils
Thats a big deal, and probably the answer to 92-94% of your engine problems.
Old Jun 18, 2007 | 01:16 PM
mooze's Avatar
Old Jun 18, 2007 | 01:17 PM
mooze's Avatar
Old Jun 18, 2007 | 01:30 PM
mikekantor's Avatar
The only thing that sticks out to me is in SUC50768, where there should be a nozzle instead of just a hose on that small valve at the back of the plenum. Thats the one you asked about here: http://forums.maxima.org/showthread.php?t=525925
Old Jun 18, 2007 | 01:32 PM
mooze's Avatar
is that some type of two piece nozzle?
Old Jun 18, 2007 | 01:48 PM
mikekantor's Avatar
Yeah sort-of , its a tiny thing and sits there connected by a short hose. Take off the hose there now and block off that port on the plenum, check how it runs. You can just stand right there and pull the trottle manually while holding a finger over the hole, and see if its any smoother.
I'm still betting on the coils.
Old Jun 18, 2007 | 03:18 PM
92 Max's Avatar
got any pix?
I can't post a picture, but in the picture in MyGreenMax94 above posted at 9:32, if you look at the picture, to the left of the throttle cables there is a red connector. Just below this is the yellow/gold tag I'm talking about.
Old Jun 18, 2007 | 08:58 PM
mooze's Avatar
so by my one coil being bad it will still not run correctly or struggle to run i should say. the idle is fine just can do anything other than that.
Old Jun 18, 2007 | 09:05 PM
mikekantor's Avatar
If the coil is so-so then it will run decent sometimes. If this has been an ongoing thing, then its probably bad already so its like running with 5 cylinders. It will be tolerable at idle, and shake like crazy at higher RPMs because there is no balance in the engine and you have 2 cylinders working against 3.
Disconnect the coil harness while its running and see if it changes, most likely there will be no difference.
Old Jun 18, 2007 | 09:09 PM
mooze's Avatar
ha thats exactly what it does. im just buying three off of hectic and see what da bizness is after.
Old Jun 19, 2007 | 08:48 AM
mikekantor's Avatar
Disconnect the opposite coil, and both their injectors. Then drive around your V4 Maxima until new coils ship in, it will run a bit smoother than on 5 cylinders.
Old Jun 19, 2007 | 12:54 PM
mooze's Avatar
wouldn't that mean i have to remove the plenum
Old Jun 19, 2007 | 01:15 PM
mikekantor's Avatar
You mean you dont want to pull the plenum just for kicks?
The cable going to the rear injectors actually connects to a single harness thats not under the plenum, but it may be tricky to block the pins for a single injector.
I guess leave that injector alone for now, it will just spew out a bit of fuel, but disconnecting stuff on the opposite cylinder should make the car slightly more "driveable" while you wait.
Old Jun 19, 2007 | 01:38 PM
mooze's Avatar
i unplugged the others does seem a bit more stable but idk i think ill just wait it out. im off for today and 2morrow, my girl is working both days so i really have no place to go. patience is the key
lowpost99
Oct 26, 2025 06:53 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
bumpypickle
Sep 20, 2015 08:22 AM
