What Tools Are Needed For Brakes?
Old Jun 18, 2007 | 07:54 AM
ninjasword71's Avatar
My front brake pads and rotors need replacing. I have done it on other cars, so I will do it myself. What tools do I need for this job wrench sizes and so on?
Old Jun 18, 2007 | 08:09 AM
Mr.Davon24's Avatar
What I used was a socket wrench, can't remember which size socket. p/b lub and a clamp.
Old Jun 18, 2007 | 08:16 AM
Greeny's Avatar
¯\(°_o)/¯
1. Lug wrench(doh)/good quality jack/w jack stands
2. 14mm socket for caliper bolts (with rachet of course,doh)
3. 19mm socket (preferably 1/2" drive) for the caliper bracket
4. Pair of needle nose pliers come in handy,but not necessary.
4. Hammer(rotor may be seized on to the hub)
5. Large C Clamp to retract the caliper piston for new pads..
6. Brake parts grease for the slide pins/pad shims
7.Brake parts cleaner to remove the anti-rust film from the new rotors.
8. 10mm wrench or deep well socket for the bleeder screw..
9. Instructions. http://www1.autozone.com/newGuide,ye...epairGuide.htm
Thats about it,i prolly missed some little dodad somewhere though..
Old Jun 18, 2007 | 08:25 AM
mikekantor's Avatar
This may be obvious, but just in case... make sure you use 6-point sockets, those bolts are tight.
Old Jun 18, 2007 | 08:37 AM
Mr.Davon24's Avatar
well said
Old Jun 18, 2007 | 09:07 AM
DanNY's Avatar
Ad·min·is·tra·tor
maybe add a few socket extensions (short and long)..but looks like the list is complete.
Old Jun 18, 2007 | 09:37 AM
redwood_usa's Avatar
wire hanger - to hang the calipers and not stretch the brake hose
Old Jun 18, 2007 | 09:45 AM
Greeny's Avatar
¯\(°_o)/¯
See #3 in link below
http://www1.autozone.com/az/cds/en_u...rInfoPages.htm
Old Jun 18, 2007 | 01:02 PM
crabapple's Avatar
You're supposed to put grease on the shims??
Also, I didn't touch the grease in the slide pins. It looked ok to me, wet and well...greasy.
How important is it to get the runout of new rotors? I just put them on (cleaned them first of course).
I didn't get a chance to bleed the system because I ran out of time. I will do that though.
Everything feels good. Definitely an improvement over the worn out pads and rotors I was driving on.
One question: the boots on both caliper pistons had slight tears. Is this a big problem? It looked like there was rust inside the piston.
Old Jun 18, 2007 | 01:24 PM
mikekantor's Avatar
I think if you don’t apply some grease then you get noise during light braking because there is room for the pad to vibrate/grind a bit. I may be wrong here, but that was the explanation I was given a while ago.
Old Jun 18, 2007 | 01:28 PM
Greeny's Avatar
¯\(°_o)/¯
That is correct..the pad slide points will squeal like a **** if you don't grease them up..
Old Jun 18, 2007 | 04:28 PM
Thanks for the speedy replies, should be a piece of cake. I called an auto wrecker just to get a price on used rotors just to save some $$ and was asked what the build date was. He said that there were 2 styles depending on what the date was. I told him that mine was built on 4/91 and he said that he did not have them for that year. The auto parts stores never asked me this. ????
Old Jun 18, 2007 | 04:43 PM
Greeny's Avatar
¯\(°_o)/¯
Front rotors are the same on these cars from 1989 third gens up to about 2000 model 5th gens..
Besides that,do not replace used with used when it comes to brake rotors,99% of all rotors in junkyards are rusted beyond repair...
Old Jun 18, 2007 | 06:38 PM
saxytothemaxima's Avatar
I just did my brakes. I was wondering why they squeek.. What are the slide pins/pad shims?
Old Jun 18, 2007 | 11:31 PM
ColombianMax's Avatar
Now I must clarify something. When I was on the search for a bracket at the JY, I noticed that the 14mm bolts that go on the guide pins on 92-94s are really a 12mm on 89-91. Am I wrong here or have any of you noticed?
Old Jun 19, 2007 | 05:46 AM
Greeny's Avatar
¯\(°_o)/¯
Hmmmm...Good point john...Both my maximas are 94,so i was not aware of this,seems nissan done alot of screwy things with the brakes on these cars from 89-94..
Old Jun 19, 2007 | 05:58 AM
Greeny's Avatar
¯\(°_o)/¯
Old Jun 19, 2007 | 07:50 AM
Oh okay. Thankyou!
Old Jul 5, 2007 | 03:43 PM
dadsmax's Avatar
Get an instruction book to do the brakes or if you really do not know how to do brakes take it to someone who knows there are innocent lives in front of you. Please please!!!
Old Jul 5, 2007 | 03:47 PM
Greeny's Avatar
¯\(°_o)/¯
Look at #9 in my post of tools needed...
Matt93SE
May 24, 2019 02:58 PM
smplyamzng
Dec 13, 2015 01:19 PM
TonyJr
Aug 20, 2015 12:14 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
