power steering question
Old Jun 19, 2007 | 10:43 PM
Loco7's Avatar
hate to bring this up couldn't find anything threw the more recent threads but....
changed power steering hose recently now its whining real bad fluid levels are good but still won't go away anything i could look at or do to stop it?
Old Jun 19, 2007 | 10:57 PM
mtcookson's Avatar
I'd check the belt first. Mine did that a while back and it turned out the belt got loose (I think I forgot to tighten the tensioner or something dumb like that )
Old Jun 19, 2007 | 11:56 PM
Loco7's Avatar
I'd think so too but it didn't do it till i changed the hose. remember on another thread couple people saying they had the same problem after they changed the hose too but cant remember what thread it was on
Old Jun 20, 2007 | 04:08 AM
Greeny's Avatar
¯\(°_o)/¯
Did you bleed the p/s system of air?
If not,here is the procedure per FSM
1. Raise front of vehicle until wheels are clear of the ground
2. add fluid into tank to specified level, turn steering wheel quickly from left to right,lightly touching the steering stoppers..repeat procedure until fluid level stops going down..
3. Start engine, then repeat step 2 with the engine running...
Old Jun 20, 2007 | 05:58 AM
LvR's Avatar
LvR
If you poor whiners have properly bled/primed/filled the system, then the correct answer is to go back to the guy that supplied the hoses - especially the suction hose ................... and whack the guy on the nose with it ............ repeatedly.
If that hose has an inside diameter smaller than (actual hose) or a banjo coupling with less than the original couplings flow characteristics, pump cavitation is caused due to inadequate flow and the result is the whining sound.
Old Jun 20, 2007 | 11:36 PM
Loco7's Avatar
well i guess i will try bleeding it and i got the hose from schmucks so who knows about the diameter
pkfinn
Jan 3, 2016 02:55 PM
iflexsteel
Sep 15, 2015 03:37 AM
Johnny9595
Sep 3, 2015 05:18 AM
hydriplex
Aug 28, 2015 02:13 PM
scarletsosa
Aug 17, 2015 09:09 PM
