V-Manage from Greddy or Trust
Old Jun 28, 2007 | 08:13 PM
braxsusriely's Avatar
So i was looking for other things to try on our VE30DE engines to work with the VTC's and i found this on greddy's site. Didn't know if the CVTC is the same across all equipped engines
http://www.greddy.com/products/displ...SubCategory=72
Old Jun 28, 2007 | 08:47 PM
mikekantor's Avatar
CVTC: Continuously Variable Timing Control
VTC: Variable Timing Control
The VTC is not capable of a gradual adjustment, its either on or off. So no, this wont work on the VE.
Old Jun 28, 2007 | 08:54 PM
Greeny's Avatar
¯\(°_o)/¯
Most likely,the greddy unit would only be compatible with an OBDII ecu setup,(3rd gens are OBDI)..Also,IIRC the cvtc units do not even function in the same manor as our vtcs...
here's some interesting reading on the subject for you..
http://forums.maxima.org/showthread.php?t=500558
http://forums.maxima.org/showthread.php?t=476664
Old Jun 28, 2007 | 09:01 PM
nismology's Avatar
The V-manage is compatible with on/off type cam-phasing systems as well.
Old Jun 28, 2007 | 09:04 PM
Greeny's Avatar
¯\(°_o)/¯
Haha..nice name change..
So the v manage is compatible with our OBDI ecu? hmmmmm..
Old Jun 28, 2007 | 09:27 PM
mikekantor's Avatar
VE ECU is also capable of this, and was designed for it, where is the benefit?
For just over price of this one thing I am currently able to purchase enough equipment, tools, and parts to pull my engine, execute many repairs, and add 5 performance mods. Bang for the buck.
Old Jun 28, 2007 | 09:28 PM
nismology's Avatar
I had nothing to do with it, I swear.....
Well I'm not sure if it will work for you guys specifically or not. I just know that it's compatible with some on/off-type systems.
Old Jun 28, 2007 | 09:29 PM
nismology's Avatar
Then don't buy it. There's nothing wrong with a discussion.
Old Jun 28, 2007 | 09:33 PM
Jeff92se's Avatar
I'm needing a caw
Well I don't know how much timing you want to do but the new Apexi Neo can control VTEC so it should be able to control the VTC on ours also.
Old Jun 28, 2007 | 09:40 PM
nismology's Avatar
So should any other RPM switch for that matter, right?
mikekantor's Avatar
So is there a benefit to these controls for the VE? By default the ECU activates/deactivates them at specified load levels. Just some voltage levels and on/off voltage sending, a circuit like that can be easily made on a breadboard without the high-tech stuff. The question I'm eventually getting to is... can we expect any benefit on top of what Nissan already designed?
Old Jun 28, 2007 | 09:42 PM
nismology's Avatar
Probably not with stock cams.
Old Jun 28, 2007 | 09:45 PM
Jeff92se's Avatar
I'm needing a caw
He wanted to find out something that works WITH the VTCs as in conjunction with. Not just control it only. Do I think there's potential with fiddling with the on/off times? Not in particular but it's possible. The VTCs actually are just off then on. They are off / on / off though the rpm range.
Old Jun 29, 2007 | 09:19 AM
after doing some more research it seems that the old VTCs like mine can change up to 15degrees while new ones go even farther. VTEC i thought was on or off just engaging the other lobes on the shaft.
the reason i want it is to engage them partialy to keep oil flowing to the VTC area and quite the noise down. I've grounded them before but i don't want to sacrifice that power. Mr.Gone somewhere i think had mentioned making a switch for the VTCs but i don't know how to make one.
Also the VTCs i belive are the problem of the VE not being able to be boosted. so with the v-manange along with a boost/ecu controller.. (i'm thinking megasquirt) we could run some boost. (not 27psi like someone posted )
Old Jun 29, 2007 | 09:20 AM
oh i didn't know until reading those links to other threads we already knew of these things
Old Jun 29, 2007 | 12:05 PM
505max94se's Avatar
I think the best thing to do is to use an rpm switch. Keep them on from idle to roughly 3500 rpm and then keep them off from 3500 and up.This way, your vtc's wouldn't clack at idle and you wouldn't lose any power up top.
Old Jun 29, 2007 | 12:14 PM
Greeny's Avatar
¯\(°_o)/¯
They wouldn't clack even if the vtc spring is old-n-worn?
Old Jun 29, 2007 | 12:39 PM
505max94se's Avatar
If the spring is REALLY worn out then yes it would clack. It's just a nice temporary fix that wouldn't cause you to lose high end power.
Old Jun 29, 2007 | 12:44 PM
Greeny's Avatar
¯\(°_o)/¯
My hopes-n-dreams are crushed...
Old Jun 29, 2007 | 12:52 PM
switches
not sure how to make a switch for this type of thing but. If all else falls for trying to just cheat it, i will by a new tensioner,spring, set. all little of subject but does anyone have a diagram of the OBD interface? i have an ecu but i'm still looking for those other things that arn't connected to the ecu. Thanks
Old Jun 29, 2007 | 01:22 PM
NmexMAX's Avatar
dot dot dot ...
Thought this link was pertinent. Even if it's not, it's good
Old Jun 29, 2007 | 01:27 PM
CyMax's Avatar
Now my brain hurts.
Old Jun 29, 2007 | 01:28 PM
Jeff92se's Avatar
I'm needing a caw
I don't think you car "partially" activate the VE30DE VTCs. It's either on/off
Old Jun 29, 2007 | 01:35 PM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by CyMax
Now my brain hurts.
Starts sticking after the 3rd or 4th time.
Old Jun 29, 2007 | 01:54 PM
mikekantor's Avatar
...which lower manufacturing costs and costs to the consumer.
Lol tell that to the people with blown chain covers.
Old Jun 29, 2007 | 01:56 PM
NmexMAX's Avatar
dot dot dot ...
Leave me alone! At once! I didn't write it! . I just hope my VQ35 doesn't start with that crap.
Old Jun 29, 2007 | 02:07 PM
mikekantor's Avatar
Haha I know, just poking some fun. Plus imagine the flaming if I posted that to a 4 y/o thread!
Old Jun 29, 2007 | 02:28 PM
NmexMAX's Avatar
dot dot dot ...
You'd be surprised what happens on the 4th gen forum. i.e. 's bumping 12,000 year old threads
Cripes, 18,900 posts..
Old Jun 29, 2007 | 02:37 PM
Greeny's Avatar
¯\(°_o)/¯
The 4th gen forum is a travesty..
Old Jun 30, 2007 | 05:35 PM
MrGone's Avatar
I'm tempted to buy one
Old Jun 30, 2007 | 05:39 PM
Greeny's Avatar
¯\(°_o)/¯
For the minibike?
Old Jul 2, 2007 | 11:42 AM
Jeff583's Avatar
I am buying one, only because i can get a great deal on one, and i am curious to see results on a VE.
Old Jul 2, 2007 | 12:33 PM
MrGone's Avatar
You'll want a wideband
They are fun
Old Jul 2, 2007 | 12:58 PM
Greeny's Avatar
¯\(°_o)/¯
They are fun
Elaborate?(curse word)
Old Jul 2, 2007 | 01:06 PM
MrGone's Avatar
SAFC-II's are a ton of fun but you'll want a wideband O2 sensor otherwise you'll be shooting in the dark.
Old Jul 3, 2007 | 12:14 AM
Jeff583's Avatar
Does anyone know where to find a good deal on a wideband O2 sensor, and maybe even a A/F guage and sensor?
Old Jul 3, 2007 | 11:34 AM
Alex_V
http://www.msefi.com/viewtopic.php?t...&highlight=jaw
Keep in mind thats just a controller for a wideband sensor, you still need the actual sensor and that is another $40-60. But thats as cheap as your going to get for a WBo2 setup.
~Alex
Apr 16, 2020 05:15 AM
BkGreen97
Apr 2, 2016 05:47 AM
Socalstillen
Sep 26, 2015 12:01 PM
