help my gauages went out!!
Old Jul 17, 2001 | 11:19 PM
killamaxi
hey tonight when i got off work..i started up my car and when i went to turn on tha lights like only my lightz cam on..but my gauages wouldnt light-up...it was like i was driving blind on tha freeway..i didnt kno how fast i was goin...can somone help???
Old Jul 17, 2001 | 11:37 PM
TB-MaxSE-89's Avatar
Gauges
Does your speedometer and other gaiges work cause if they dont you might have to get a new gauge pod. otherwise if its just the light its probably located in the pod somwhere and is burnt out, also check your fuses.
Old Jul 18, 2001 | 12:40 AM
killamaxi
ok
where would i get a new gauge pod from...and how much?
Old Jul 18, 2001 | 05:44 AM
Isaacm's Avatar
Re: ok
I got an entire cluster out of a '93 SE for $50 at the boneyard. Every other yard wanted at leat $85. Dealer is like $550 or something. SE clusters will cost more the GXE, at least they do around here. (MN)
Old Jul 18, 2001 | 05:56 AM
Isaacm's Avatar
Re: ok
Old Jul 18, 2001 | 07:19 AM
FFxI30's Avatar
Re: ok
There are always some gauges for sale on ebay. This is prob gonna give you the best price. If you dont care what kinda gauges you get you will find the GXE's to be much cheaper. Here is a set of SE's that will prob go cheap because he spelled the title wrong. IMO the SE's look much better too.
http://cgi.ebay.com/ebaymotors/aw-cg...306098&r=0&t=0
I just upgraded mine to the SE's and it was pretty easy.
Old Jul 18, 2001 | 03:25 PM
N34JZ's Avatar
Needs non-Maxima Friends
happened to me a few months back
check the fuses . i forget which one but that did the trick.
Old Jul 18, 2001 | 04:02 PM
ghostmax's Avatar
killamaxi
It's most likely your fuses. Look in the fuse box under your steering wheel. The instrument fuse and the taillights are all on the same fuse, so if your taillights don't work (but your brake lights do), then it's definitely your fuse. Just replace with the same amp fuse, available at any parts store. Good luck.
Old Jul 18, 2001 | 08:30 PM
Re: Re: ok
where in MN do you live? I live by downtown St. Paul.
Old Jul 19, 2001 | 08:44 AM
Isaacm's Avatar
Re: Re: Re: ok
I'm in Hutchinson, about 50 miles west of Minneapolis. I only know of about 3 other peeps on the board from MN. Good to know ya!
P.S. Sorry for the double post back there everyone.
Old Jul 23, 2001 | 07:58 AM
Re: Re: Re: Re: ok
do you go down to university on the weekends at all?
Old Jul 23, 2001 | 04:18 PM
KlimaxSE's Avatar
i have had the same problem recently. i checked the fuses and it WAS the problem. if you're wondering, it is the 3rd red 10 fuse from the top on the left side that says "taillights". the only problem i still have is that every time i replace the fuse, it ends up blowing out a day and a half later again. i am thinking it is an electrical short in the system but im not sure. if anyone can help me, please do. thanks.
i hope i was of some help to the fuse problem.
Rocky Davis
22
Mar 28, 2014 07:11 AM
porkapine
May 8, 2013 01:18 PM
SouthFlMaxTech
Apr 4, 2009 09:31 PM
SYCEFIRO
May 25, 2001 08:00 AM
