engine stalling
Old Jul 16, 2007 | 08:59 PM
mooze's Avatar
engine stalling
i just finished redoing my injectors as 2 were leaking. it was running fine with leaks but thats a big no-no. so got them in correctly with no leaks. start the car and it runs like crap. idle jumping and has mad skips. ran it down the road to see if it would clear up as it had a light skip last time i replaced injectors that went away after being opened up. this time it doesnt even want to catch idle just cranks sputters and dies already replaced coils and plugs so......
Old Jul 17, 2007 | 03:30 AM
Greeny's Avatar
¯\(°_o)/¯
List all the parts you have replaced on this car,also specify if they were new or used parts.
Old Jul 17, 2007 | 06:19 AM
mikekantor's Avatar
+1 yeah lets sum up where we are now.
That VE has a grudge against you mooze.
Old Jul 17, 2007 | 07:45 AM
mooze's Avatar
knock sensor-new
knock sensor harness-new
3 front coils-new
2 rear coils-used but from working car
1 rear coil-new
all gaskets new
injectors-used but from working vehicle
most vacuum lines-new
fuel filter-new
intake filter-new
i dont think its the coils as it doesnt shake like it did last time. it just wants to die
Old Jul 17, 2007 | 08:14 AM
mooze's Avatar
it starts and comes down like its going to idle but it goes right pass 700 and gets 2 like 200 and then tries then dies. sounds like i have a vacuum leak but cant find it. throttle body leak sound the same?
Old Jul 17, 2007 | 09:06 AM
Greeny's Avatar
¯\(°_o)/¯
Have you tried a new/good used mass air flow sensor?
If not,do so..
You also may need to clean your iacv/throttle body with some throttle body cleaner,not carb cleaner..Or you may have a bad iacv/coolant temp sensor..
Any vacuum leak is going to sound the same,regardless of where it is
I wish you lived closer to me,we could swap out some extra parts i have laying around/parts off my ve until we found the problem...Maybe we can get our schedules worked out for a meet up sometime..
I am also leaning a little toward mechanical error on your part(no flame intended)you have replaced a bunch of parts on this engine,and have made some mistakes in the process,the injector leak was easy for you to see due to the gas leaking/gas odor,but their may be parts of your repair work that you have done incorrectly that you cannot see that may be causing this issue.
Old Jul 17, 2007 | 09:28 AM
mooze's Avatar
well prior to fixing injector it was perfect. now after having to take everything apart again it starts to fail. ill try another gasket.
with the meeting up i would b for it but cant as the car wont stay running
Old Jul 17, 2007 | 09:58 AM
internetautomar's Avatar
mod or sell?
I'm going to blame the injectors.
Old Jul 17, 2007 | 10:27 AM
mooze's Avatar
well ill fix leak and go from there throttle body was leaking
Old Jul 17, 2007 | 11:53 AM
mikekantor's Avatar
Non-rubber gaskets should be replaced every time I think. They dont reshape, I think the thin black stuff on there gets crushed and then gets heated by the engine to soften and fill tiny areas for a proper seal. Someone should correct me if I am wrong on this, but from looking at them I cant imagine any other way those things can function as gaskets. When you expose it, it wont seal back exactly the same way so you will have leaks.
Old Jul 17, 2007 | 12:28 PM
mooze's Avatar
ok made a new gasket and it runs and holds idle for a while. but holy **** now i can hear the big problem. there is a leak or something near the front of plenum or the fuel rail or something. i torqued them down but theres something there. sounds like a lot of rushing air. car still skips so any suggestions?
Old Jul 17, 2007 | 01:14 PM
Greeny's Avatar
¯\(°_o)/¯
I'm free all next week..
Old Jul 17, 2007 | 01:35 PM
mikekantor's Avatar
Isolate the leak is a suggestion. Is it from the plenum, or the front valve cover? Its not the fuel rail because you hear the leak instead of seeing a bunch of fuel everywhere.
Did you follow my advice from the other thread about tightening the plenum? Line it up and get the bolts in loosely everywhere, then tighten the front six, and then torque them down in proper order, then tighten the rear four.
Metal can bend so little that you wont see it, but it will be enough not to hold pressure. Thats why you have to tighten the bolts in order, and start with the right ones too.
Old Jul 17, 2007 | 01:41 PM
mikekantor's Avatar
Q: Are you making a new gasket each time instead of using the Nissan gaskets? Thats understandable because it seems like you took your plenum off a few dozen times already, but I remember you mentioned black smoke before. Is it possible that that time the gasket didnt have enough time to dry, some parts were sucked in, and burned to give the smoke?
Old Jul 17, 2007 | 08:40 PM
mooze's Avatar
plenum leak
Old Jul 17, 2007 | 08:42 PM
mooze's Avatar
using beck and arnley gaskets
James92SE
142
Jan 2, 2024 09:23 AM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
97_GXE
Sep 15, 2015 06:47 AM
