Is this how it ends?
Old Aug 16, 2007 | 09:24 AM
mikekantor's Avatar
I just got a call from home that my car is deep in water from the rain we are having here today. Although I dont hold highly the opinion of the person who called me, she says the car may be carried away by the water.
Old Aug 16, 2007 | 10:03 AM
gapboi210's Avatar
and ur just sitting in front of the computer typing?
Old Aug 16, 2007 | 10:13 AM
prappl's Avatar
Yeah dude, what's the problem. Swim out there and hold onto your car so it doesn't get washed away.
Old Aug 16, 2007 | 10:14 AM
mikekantor's Avatar
Correct, sitting at work and typing. Not much I can do at the moment. Whatever can happen has already happened. If there is enough water to carry it away then I have no hope of getting to it, much less driving to higher ground.
Old Aug 16, 2007 | 10:20 AM
largepkg25's Avatar
That's like letting go of my child and saying oh well. F'that! I'd be swimming to that somebich, throwing it in neutral and pushing my love to safety! I couldn't let her die alone like that, never!
Old Aug 16, 2007 | 10:21 AM
Greeny's Avatar
¯\(°_o)/¯
+1 stay where you are,the car is not worth your safety. Not to mention you could be in the way of rescue efforts in the area.
Sorry to hear though..
Old Aug 16, 2007 | 10:23 AM
Pearl93VE's Avatar
I can has?
Here in downtown St. Augustine it floods like 2-3.5 feet downtown in some area's. My mom used to take the VG to work almost every day and it would sometimes flood like that. It really didn't ever have a problem although she usually parked it in her little VIP spot. But it has seen 3 feet of water and I've never had a problem with it...
Old Aug 16, 2007 | 10:25 AM
mikekantor's Avatar
The weather has calmed down, and from what I hear the car is still in the same place I left it, I'll check it out once I get home.
Old Aug 16, 2007 | 10:26 AM
Bufflomike's Avatar
Sexier Than Simpson
Make sure you get her to take pics and post them.
Old Aug 16, 2007 | 10:27 AM
Greeny's Avatar
¯\(°_o)/¯
Don't forget pics of the carnage.
Old Aug 16, 2007 | 10:41 AM
mikekantor's Avatar
If there is water inside, I'll try to get video of it pouring out as I open the door.
Matt93SE's Avatar
STFU n00b!
Certain places in Houston will get 15-20 ft under water during heavy rains. the companies that are supposed to be maintaining the pumps and such to keep the low lying areas pumped clear aren't doing their stuff and the city isn't doing anything about it. always been that way, always will.
Old Aug 16, 2007 | 11:29 AM
maxitech's Avatar
Yet another reason why I will never live in Texas...
Old Aug 16, 2007 | 12:33 PM
Maximahappy22's Avatar
Make sure you dont crank the engine until you emtpy the water out of the airbox if it got that high.
Old Aug 16, 2007 | 12:49 PM
mikekantor's Avatar
No airbox... I got a CAI but havent finished the installation so at the moment it is a HAI.
Old Aug 16, 2007 | 12:54 PM
internetautomar's Avatar
mod or sell?
pull the plugs before cranking over the engine!
then crank it to get out any water that may have gotten in.
an immediate oil change is also a must.
Old Aug 16, 2007 | 01:35 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
also if you have an a/t some water could have gotten up into that air hose at the top of your transmission.
Old Aug 16, 2007 | 07:23 PM
mikekantor's Avatar
The interior was completely dry, good job building the car Nissan!
Dirt all over the wheel, leaf in caliper, rusty disc, water for sure made it over the wheel:
Stuffed with tree crap:
Everything inside was completely filled with this stuff, every crevice, in the belts, on top of the y-pipe, inside the engine mounts:
Looks like the water cleared the AC compressor, and occasionally splashed the front of the valve cover. Starter and alternator were submerged for sure, but relays, the battery, coils, injectors, etc did not get wet. I dont think any water got into the intake, maybe a bit splashed the cone filter, but there wouldnt be enough to make it all the way up to the throttle or blow-by hoses.
I cleaned as much as I could reach, but did not try to start it. I think there may be twigs inside the alternator, and more stuff on the y-pipe and cat. I dont want sparks or fire, so for now it will sit and dry. Tomorrow I'll get under it to clean more of this stuff out, and I'll try to spin the alternator and see if it can spin freely, or if I need to take it off and clean it thoroughly.
RE: Oil, I have front and rear main seal leaks, but its not like they are gushing oil, its a few drops here and there. Water could've gotten in there, not sure, so I'll change oil.
RE: A/T, I do have an Auto. I dont think the water could get in through the breather, but it is possible that some got in through the A/T dip stick.
My mom's 325i got caught in water while she was driving today, and it was towed back to her house. I installed a new air filter, and new spark plugs. After what seemed like eternity of spinning the starter, it stubbornly awoke and water came gushing out the tail pipes. I did a test drive after revving it a bit and doing a few restarts, that car is back to normal now, but I didnt expect it to survive the ordeal, very impressive. It will be getting new oil ASAP.
Old Aug 16, 2007 | 07:24 PM
mikekantor's Avatar
Old Aug 16, 2007 | 07:59 PM
nForce's Avatar
The Computer Guy
Take a nice pressure wash to that
Old Aug 16, 2007 | 08:01 PM
mikekantor's Avatar
But... I already cleaned it.
Old Aug 16, 2007 | 08:11 PM
so are you just going to remove the belts, grille, engine bay guards, and whatever else you can uninstall without opening any fluid circuits, and just yank that crap out?
gosh your radiator fins... are probably crudded up. and your condenser too.
Old Aug 16, 2007 | 08:16 PM
mikekantor's Avatar
All that stuff is already cleaned out, there is some left around the y-pipe, which I will clean tomorrow when I'm under the car. I used a hose with a light flow of water, and my hands, to sweep everything out.
Old Aug 16, 2007 | 08:51 PM
AM_BlackMax's Avatar
Fox Body FTW
Hate to see that happen to any car.. good thing it didn't do too much damage and didn't float away
Old Aug 17, 2007 | 04:58 AM
Bufflomike's Avatar
Sexier Than Simpson
Wow, I thought you might have been exaggerating, but that is crazy. I will take the snow over the flooding, tornadoes, wild fires, hurricanes.
Old Aug 17, 2007 | 06:20 AM
mikekantor's Avatar
Thankfully this state is large enough to have the wild fires on one end, tornadoes on the other, and flooding/hurricanes only hitting a few specific places. I lived in Austin during Katrina and the weather was fine there. Had I been in Houston, I could've at least prepared and parked my car in a tall garage. Over 6 years of living in the state this is the first time this has happened to me, although the last time Houston was flooded like this was 6 years ago, just before I moved down.
Old Aug 17, 2007 | 06:46 AM
Cliff Clavin's Avatar
Way out West
Oregon has some fires and floods, but they usually only impact a very small percent of the population. It is crazy how big this country is and how different the weather can be from place to place.
Good luck with the car, Mike. Hopefully everything makes it out OK. It sounds like you have a good plan for keeping it alive.
Old Aug 17, 2007 | 06:51 AM
Bufflomike's Avatar
Sexier Than Simpson
I lived in Portland for 8 years. We had a stretch of 42 days with no sun.
Old Aug 17, 2007 | 07:40 AM
mod or sell?
all we get in Chicago are temperature extremes.
no hurricanes, no massive snow storms, no wild fires, no tornadoes (in the city).
we do get rain, and our roads flood in certain area.
we get snow but usually only a foot or so at a time.
Old Aug 17, 2007 | 07:47 AM
Pearl93VE's Avatar
I can has?
wow...
I guess I don't know the real meaning of the word flood...
Ours wasn't near as bad as that, I guess because it was JUST water, no debris. Ouch, looks like you'll be having fun with that the next few days...
Old Aug 17, 2007 | 08:31 AM
mod or sell?
power washer....
Old Aug 17, 2007 | 11:20 AM
in raleigh, an inch of snow closes the schools. but that's because nobody in the south understands the concepts of torque vs traction, and thusly, can't drive in snow.
Old Aug 17, 2007 | 12:21 PM
Way out West
I live in The Dalles. I don't think we have had measurable rain here since late May or early June. Allegedly, we have over 300 days of sunshine. I think it's more like 300+ days without rain, but sometimes we will get a winter inversion for a few weeks at a time that is depressing. We also have a fair amount of wind.
I am from the Portland area, though, and I got very sick of rain. I would think the massive snow in Buffalo would be worse than rain. I have seen pictures in my union magazine of letter carriers there trying to deliver mail in snow that was over their heads. People had to carve out tunnels to their front porches...
Old Aug 17, 2007 | 12:25 PM
mikekantor's Avatar
... I have seen pictures in my union magazine of letter carriers there trying to deliver mail in snow that was over their heads. People had to carve out tunnels to their front porches...
"Neither Rain, Nor Sleet, Nor gloom of night"
When I lived in Wisconsin, 8" of snow wouldnt even close the schools.
Old Aug 17, 2007 | 04:07 PM
mikekantor's Avatar
all is not how it seems
Came inside to get the multimeter, and leave a quick update:
Interior WAS in water, and it stinks now. I was wondering why there was so much condensation inside the windows as I came near it. I think the OmniFi is dead, it was near the front passenger feet area. Not sure about ECU yet.
I got my 3-ton jack out to lift up the front end, that let the water drain from the exhaust.
Car wont start, I think the battery is dead, so I'm going out to check it. While I wait for another car to jump from, I'll be checking other electrical stuff, and the intake as well.
Old Aug 17, 2007 | 04:36 PM
goon9's Avatar
Makes me think of the time I drove in a couple feet of water. Only I didn't have any problem because it was running. Glad to see your trying to save it
Old Aug 17, 2007 | 07:50 PM
Way out West
those aren't good signs...
Old Aug 17, 2007 | 09:21 PM
mikekantor's Avatar
You cant get rid of me that easy...
The jump worked quite fine, engine ran great, kept spewing steam and water out the tail pipe for a while. Some of the leaves I didnt see or couldnt reach sent up some smoke and gave a pleasant "campfire" aroma, but beyond that they were no trouble.
After a short test drive around the block, I pulled into the garage, and started tearing it apart.
Got the seats out. Got the carpet out, but had to cut it a bit by the ECU, not a clever design IMO. Cleaned up all the standing water didnt saturate the carpet, the drain plugs helped big time. Then cleaned more with some household cleaners. Also found a penny, some gum, and a pen!
After these photos, I installed the driver's seat, and some of the buttons.
I think the carpet may be salvageable after a good wash with some soap, it will however require new foam to go underneath but I think I have a source for that. The seats all absorbed water, even though it wasnt that deep inside, they just took it up anyway because they are essentially big spunges. The driver's seat took on the least water, but I'm sure they will all stink soon enough. Someone also told me that I might see problems with the wheel bearings because they were submerged in water, anyone want to comment on that?
So now I'm searching for locally-available 3'rd gen seats, might stop by some of the salvage places tomorrow, although they all leave seats inside the car when its put out to pasture so I doubt I'll find anything good unless I'm patient.
Old Aug 17, 2007 | 10:58 PM
ColombianMax's Avatar
I got 2 front plush seats I can sell dirt cheap and can ship really fast with my Fedex 75% discount I need em outta the garage
Old Aug 17, 2007 | 11:05 PM
mikekantor's Avatar
I'm going to look at some tomorrow morning, so I'll let you know right after that. Got photos?
