Need help with a problem
Old Aug 27, 2007 | 02:58 PM
Maxteca's Avatar
I have a problem with my car its a 93 gxe. The car runs like crap, What is is doing is when I start it and is in park it idles fine but once I put the car into drive the idle drops to 300-500 and it runs like its not hiting on all cylinders. But
once you get going like 45 mph its fine.
Old Aug 27, 2007 | 03:13 PM
Maxteca's Avatar
If this helps I did seafoam the car today with no difference. I was thinking about
replacing all the vacuum lines.
Old Aug 27, 2007 | 03:18 PM
redwood_usa's Avatar
Start by cleaning your IACV ( about 15 mins of work) and then adjust it to idle at 750 rpm. Then come back with results.
Old Aug 27, 2007 | 03:22 PM
Greeny's Avatar
¯\(°_o)/¯
How long since your last tune up?
Old Aug 27, 2007 | 03:53 PM
Maxteca's Avatar
Ok cleaned my IACV and set the idle but it would not let me set it above 650 rpms and its still not running right. My last tune up was about 3000 miles ago
Old Aug 27, 2007 | 05:46 PM
You have got a bad IACV most probably.
Old Aug 27, 2007 | 06:05 PM
ColombianMax's Avatar
I had that problem before and I thought IACV was bad but appearantly I jumped to conclusions too fast. So Maxpwer91 went ahead and adjusted the THROTTLE CABLE for me and voila, more responsive acceleration and idle can be actually adjusted through IACV
Old Aug 27, 2007 | 06:08 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
clean the MAF while you're at it. just a weiner of a suggestion (did i really just say that???) but it's just one of those things.
Old Aug 27, 2007 | 06:10 PM
I dont know...for some reason Im thinkin an injector or 2 as well for the fact that he said that after 45 it seems fine
Old Aug 27, 2007 | 06:44 PM
Maxteca's Avatar
I was thinking it might be an injector but I was hoping for some kind of quick fix.
So how do I test the injectors.
Old Aug 27, 2007 | 06:54 PM
maxitech's Avatar
The best way is to get a mechanic's s***hoscope (s***hoscope with a long probe on the end). Touch it to each of the injectors and listen for the clicking that means it is working. If one is bad, the clicking will be quieter since that injector isn't working and what you are hearing is coming from the other injectors. 5 out of 6 injector plugs can be reached w/o disassembling anything. Pull the plug on the one you think is bad while the car is running, and there will be no change in idle if you are correct. If it runs worse, then that injector is not the problem.
Old Aug 27, 2007 | 07:08 PM
Maxteca's Avatar
Could I just unplug the injectors one at a time instead of using a mechanic's s***hoscope?
Old Aug 28, 2007 | 04:10 AM
The best way is to get a mechanic's s***hoscope (s***hoscope with a long probe on the end). .
A long screwdriver will also work, less work than removing connectors.
MAF shouldnt be a problem as a bad MAF will let you go to 2000 rpm. Dont know about your throttle cable, but may be your TPS too. But its very surprising it wont let you go above 650. try unscrewing the idle adjusting screw fully (but dont remove) Your bypass passage may be still blocked with carbon.
Old Aug 28, 2007 | 07:21 AM
Alex_V
Theres a connector to the right (drivers side) of the intake manifold. Trace the wires for the IACV, and its the other big connector with 5 wires. You should be able to check resistance there, but you'd have to look at a diagram to know which wires to measure.
~Alex
Old Aug 30, 2007 | 09:57 PM
Well, did you find out whats wrong?
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
