pics of clutch line cooler mounting location?
Old Sep 9, 2007 | 01:58 AM
traxtar944's Avatar
Would be lost w/out the org
Does anyone have a picture or diagram of how the clutch line cooler is mounted to the car? I can't figure it out, and it's nowhere in the service manual. For those that don't know...if you look at your master cylinder and trace the line down and by the A/C line, you'll see this little distribution block and little mess of tubes wrapped around in an oval pattern, then it goes to the slave cylinder on the transmission. I have no idea where this distribution block mounts to the chassis. Any help? Thanks!
Old Sep 13, 2007 | 09:55 PM
todamax's Avatar
Its along the left fender rail, I can get a pic this weekend.
Old Sep 13, 2007 | 10:58 PM
Matt93SE's Avatar
STFU n00b!
it's not a cooler. it's a buffer. bypass it completely by mating the 10mm male and female threaded lines going into/out of it.
Old Sep 14, 2007 | 07:54 AM
traxtar944's Avatar
aaah.....good, because thats what I did. Thanks Matt.
Old Sep 15, 2007 | 02:46 PM
goon9's Avatar
Just wondering, is there any reason to bypass it? I already have a SS line, will bypassing increase response?
Old Sep 15, 2007 | 08:37 PM
Matt93SE's Avatar
STFU n00b!
not really. response is an individual thing. I like mine with the block. some like it without. it makes it easier to bleed without the block, but otherwise the pedal feels the same.
Old Sep 15, 2007 | 10:11 PM
Alex_V
I know on 240's it dampens the vibrations or something as well as lengthens the pedal travel and softens it a little. I assumed it did the same on the maxima.
~Alex
maxima-junky
Oct 21, 2015 05:17 PM
maxima-junky
Aug 13, 2015 09:59 AM
