Pic of my hyper white/red gauges
Nice!!!
it looks sweet!
once I get my lazy *** motivated I'm gonna pull my gauge cluster and do the same...but removing all that mess is so bothersome especially outside in this 90+ degree heat!
Originally posted by ghostmax
I finally got a pic of them. Sorry for the bad quality.
You have to take out the instrument cluster to replace the bulbs in the back. If you have an SE cluster (white faces), then you can do this; if you have a GXE, then you have to get SE gauges. Switch out the bulbs (4 of them) with whatever color (hyper bulbs) you want.
To take out the cluster, you have to remove the shifter panel, the radio control panel, and the top panel. There are detailed instructions somewhere on the board. Just do a search.
The bulb number is 194, and you'll need 4. I think I bought the bulbs on an ebay auction. You can get them most anywhere.
thanks
Madmax,
I didn't paint my dash. The cluster is from an '89 SE (white gauges). The red color comes from putting in hyper red bulbs in the left and right bulb slots. I put hyper whites in the two middle slots. Does this answer your question?
Madmax,
Madmax,
sorry about the misposted question.
Do you know if the GXE bulbs are the same as the SE bulbs?
Madmax,
Madmax,
The 194's are just regular white bulbs with color caps on them (green for GXE and blue for SE). The real problem is not the bulbs but the actual instrument cluster which, if you want to change the color of the lights (at night), you will have to change to white-faced (SE) gauges. Was that clear? If not, just ask.
edit: i found the post. here's the link. i searched for "green dash lights" one guy says he switched his bulbs to blue ones and they look blue, and not green. i'm going to email him in a bit. http://forums.maxima.org/showthread....en+dash+lights
Hyper white bulbs in a GXE
I just put Polarg hyper white bulbs in my dash and they still look green but much brighter and a lighter color. Like a light aqua green. They're the same 194 bulbs used in a SE. I think there's a layer of green that makes the lines still look green. I'm thinkin of takin it all apart to check it out..
Apr 16, 2020 05:15 AM
bigfrank
Oct 1, 2015 12:51 PM
