injectors....
Old Aug 17, 2001 | 12:06 AM
msoup72
I was hunting around the site and found out some valuable info with regards to fuel injectors and what to expect. Well, let me add my two cents....I recently had to replace 2 injectors also. The car was running VERY rough and yes, there was a loss of power as well. My Maxima is a 1990 SE with only 84K. The original owner also had to replace a couple injectors.
I need to know if I should use a fuel additive as a preventive means or not take the gamble?! My dad says yes; however, he doesn't own a Nissan,let alone a Maxima. What's your scoop?
Thanks,
Mark
Old Aug 17, 2001 | 12:30 AM
BeatJunky's Avatar
I need two injectors as well...
My car is VERY sluggish... Takes forever to accelerate and has a bit of "Can"like noises coming in from engine area and backfires at low rpms. Was it like this for you?
If so... did the injectors fix these symptoms up?
How does your car run now?
Old Aug 17, 2001 | 04:24 PM
bmw88rider's Avatar
You know what I found because I just got my car and they replaced the whole back bank of injectors on that because the heat off the back of the engine backed the electrocoil that controls the opening and closing of the injector tip. There was a recall for just this problem that involved a heat shield for those. call up your deal and make sure it was done or if your car is eligible,
Thanks,
Mark
Old Aug 17, 2001 | 10:07 PM
msoup72
sheild....
Heat sheild?! I'll be checking that out for SURE! Thank you very much. I had no idea of that recall or any others for that matter. I have to replace the muffler and after that's done, I'll be better able to hear and feel the engine sound, etc.
Thanks again,
Mark
Old Aug 19, 2001 | 11:20 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Really........
man...I'd never heard about thie recall, its not on the TSBs or recall sheets I've seen, but man thats really interesting, I'm gonna ask my dealer about this ASAP! thanks for the info "bmw88rider"!!
SpooledVQ35
May 5, 2009 07:23 AM
SpooledVQ35
Apr 17, 2009 11:41 AM
CapedCadaver
31
Oct 7, 2008 01:45 PM
po8pimp
Sep 14, 2007 03:33 PM
mofoaka
Jul 26, 2007 03:25 PM
