NO Heat
Old Aug 17, 2001 | 12:14 PM
blackandwhite's Avatar
To them I'm like an idol
My heater is not working, blower is okay but heater and defrost just kickout cold air? What do I fix?
Old Aug 18, 2001 | 10:40 PM
maxmizd27's Avatar
Check for leaks in your cooling system. If the cooling system looses it's charge the heater core will not operate. The car can eventually over-heat if this is what the problem is. My stainless steel radiator hoses were loose one time allowing coolant to push out of the back of the coupling, thus creating a leak. I first noticed lack of heat from the heater and eventually the car over-heated. The heater core works off of the charge from the radiator. Your fan is working, so it sounds like it's just the core. We replaced the stainless hoses with stock rubber ones, re-pressurized the system and everything was fine. Justa possibility. Lotsa Luck!
Old Aug 18, 2001 | 10:54 PM
Sonic's Avatar
Other reason: Thermostat stuck open.
Old Aug 18, 2001 | 11:12 PM
maxmizd27's Avatar
Good thinking 99. (Remember the series "Get Smart")
Leave it to me to skip the simple thing and go right to the weird stuff.
Old Aug 19, 2001 | 01:13 PM
Well...actually
But by the way, I do have a coolant leak. I can't find it though. It was overheating every 2 to 3 days before I used that Bar's Stop-Leak, then it stopped for a few weeks. But it started again today. It is a small leak that I can not find. Any common places/methods to check?
Old Aug 19, 2001 | 04:41 PM
Matt93SE's Avatar
STFU n00b!
It's possibly the freeze plugs in the block.. This is acommon problem in the older VGs. I know several 89 and 90 models that have had the freeze plugs rust through.
pull your timing belt cover off, and see if you can find anything there.. if not, check the back of the block for more- but that stuff's behing the tranny not much fun to get to. often the problem is with the ones near your water pump, so people will at first thing it's the water pump..
then again, it could be the water pump itself. they're usually only good for ~100k miles, so if youv'e got more than that, there's a good chance your pump could be failing on you.
tarun900
19
Dec 20, 2021 06:57 PM
Fbana41
Aug 29, 2016 12:18 PM
captchaos
Mar 15, 2016 12:18 PM
Derrick2k2SE
Nov 19, 2015 10:14 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
