Is anyone elses.....
Old Oct 29, 2000 | 02:52 PM
Blu Max's Avatar
wing coming off or loose on the trunk, have you fixed it?
what can i do?
Old Oct 29, 2000 | 03:40 PM
SeR's Avatar
SeR
3rd Gen. Se Wing
This happend to my bro's '89 Max (it's a common problem among 3rd gen maxes.) All he did was tear it off, and re-glue it back on with industrial strength adhesive. Then when he sold it this new owner who re-stuck it to the trunk with some kind of bolts, basically it was screwed in with metal tacs. (home-made, not done with Nissan parts)
Old Oct 29, 2000 | 04:40 PM
Maxnine's Avatar
you could buy double sided tape and use that. that's how it was done by the factory. just make sure to clean the areas to be taped.
Old Oct 29, 2000 | 08:09 PM
Just get a new wing. That is what I did
Old Oct 29, 2000 | 08:22 PM
chris92gxe's Avatar
Do you guys have that same problem with after market wings or are you having problems with the stock ones.
92GXE, touring wing, 18” racing wheels, Port&Polished intake, custom intake, custom yellow interior, racing seats, back seats taken out and replaced with subs and amps, NOS kit, Suspension tech. Lowering springs, custom grille, soon to be custom painted and have the whole engine rebuilt for big shot NOS and custom SC and tranny converted to 5-speed
Old Oct 29, 2000 | 08:46 PM
These problems are with stock wings. The aftermarket wings use conventional nuts and bolts and they are urethane or fiberglass and not that rubbery stuff
Old Oct 29, 2000 | 09:03 PM
NYCe MaXiMa's Avatar
yeah, this seems to be a common prob on 3rd gens...
Here is what I did:
My so called passenger side of the spoiler was almost off completely, so I just ripped that side off completely. Then I cleaned both surfaces, (trunk and spoiler) with rubbing alchohol and scraped any excess glue or whatever it was off the spoiler part where its attached to the trunk. Then I dropped a little crazy glue on the spoiler and put some double sided tape on it, then pressed the other side of the tape up against the trunk and held it down for 4 minutes. Thing holds better then stock for the last 4 months.
I've done the same procedure to passenger and driver side door molding since I got the car with passenger side molding allready halfway torn off and just hanging freely. I wanted to simply use tape and glue to reattach it, but the molding was curled up from wheather and **** like that so I tore it off, then broke it in half by mistake, had to compress it and crazy glue it back together, reatached it at warm (65 degrees) wheather. Holds better then stock for months now. Just make sure your spoiler is straight when you reattach it.
