Update on coolant leak...
Old Oct 1, 2001 | 07:46 AM
fatKID
OK... I think I found the leak... but I don't know if it is a major problem or not... The leak is coming from one of the Heat core hoses (not the rubber hose part, but the metal pipe coming out of the block. Right where one of the pipes conects with the block it is leaking. I'm not sure if it is the in or out for the heating core. Has anyone seen this before... and do you know if it is a major problem to repair???
Old Oct 1, 2001 | 08:37 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Update on coolant leak...
ahhh so i was right
well jeff 92se can answer the detailed questions for u. but the heater core is not a ez job.
Old Oct 1, 2001 | 08:43 AM
fatKID
Yep... It was the heat core system... Thanks for giving me the idea to look there... I was busy looking under my car when I needed to be looking under the hood at the upper part of the block. Thanks... Now I just need to know it I can replace that metal tubing going into the block...
Old Oct 1, 2001 | 08:44 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: Update on coolant leak...
metal tubing going in the block..u mean going into the heater core right? not to the engine block?
Old Oct 1, 2001 | 08:50 AM
fatKID
No... The metal tubing going in to the engine. There are 2 hoses that come out from the fire wall to the engine (One to the heat core the other from the heat core) One of these hoses is leaking... It is not the rubber part of the hose that is leaking but a metal pipe sticking out from the top of the engine block (that contacts to the hose) is leaking... possibly a crack... My question is can these pipes be unscrewd from the engine and replaced?
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
mkaresh
Mar 12, 2018 06:48 PM
Hdnseek
Sep 9, 2015 05:55 AM
