Turning lights not working, need opinions
Old Oct 12, 2001 | 07:13 PM
Valadez_jr's Avatar
My turning lightts went out on my 3rd generation. The blinkers are out. I checked the bulbs and the look fine. I also checked the fuses under the hood. They are good too. I don't know what else it could be.
Old Oct 12, 2001 | 07:43 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Re: Turning lights not working, need opinions
i have a 4th gen and they have fuses under the steering wheel near where the hood latch is. do you have a fuse panel near there?
Old Oct 12, 2001 | 07:51 PM
Valadez_jr's Avatar
Re: Re: Turning lights not working, need opinions
Yes, I checked the fuse box already. This problem just started. I was thinking maybe a light burnt out but I dont think both turning lights would not work.
Old Oct 12, 2001 | 08:04 PM
Bags's Avatar
Re: Re: Re: Turning lights not working, need opinions
hmm, i don't think that both bulbs went bad. are there any other bulbs in you car that are the same as the turn signals? if so replace 1 of the blubs with that bulb. if not do you have a meter? i see you said you checked the fuses. in your first post i thought you cehcked under your hood, did yoy check for any fuses under your hood?
Old Oct 12, 2001 | 09:54 PM
Valadez_jr's Avatar
Re: Re: Re: Re: Turning lights not working, need opinions
Yes I checked under the hood and inside the car. I have to test the connections to the fuses. I brought a repair manual. Luckily this happened friday where I am able to work on it this weekend. I would hate to take it to an electrician, exspensive!!!. Thank for your help.
Old Oct 13, 2001 | 06:22 AM
FroMan's Avatar
do the little arrow lights in the car blink? if no the turn signal switch may be bad. If they do turn on, check the wiring for any sort of short or bad ground. Perhaps someone could scan the wiring diagrams and take a quick peak at it to help you out. My dad has my old FSM, so i'm just taking a shot in the dark
Fro
Old Oct 13, 2001 | 09:07 PM
Valadez_jr's Avatar
Fro
I found out what the problem was. Before all this happened I took off the heater/stereo panel to see why my a/c was shutting off sometimes. When I did that I had to disconnect the hazard light wiring. The turning lights some how are linked in with them. So problem solved. Thanks for all the help.
Old Oct 13, 2001 | 09:16 PM
FroMan's Avatar
no problem! glad you figured it out!
Fro
jerrod99_se-l
Aug 27, 2015 08:27 PM
doctorpullit
Aug 20, 2015 05:15 PM
beboski
Aug 16, 2015 05:23 PM
kirkhilles
Aug 8, 2015 10:53 AM
kenc15
Aug 5, 2015 08:29 AM
