Valves&Heads
Old Oct 15, 2001 | 09:59 AM
hillstreet's Avatar
Valves&Heads
I'm about to have the heads removed and worked
are there any tweaks to do while I'm in there to
get horsepower added?
Old Oct 15, 2001 | 10:35 AM
flyry110's Avatar
port and polish if you have the money. otherwise maybe a multiangle valve job. should cost ya like 50 bucks. well, that's how much my guy is. depends on how many valves.
Old Oct 15, 2001 | 01:24 PM
NZ Max's Avatar
Can you tell me what a multui angle valve job is?
Old Oct 15, 2001 | 01:45 PM
Bman's Avatar
Valves normally have 1 angle cut into them (I forget - 45 degrees?) that meets the valve seat in the head (which has an identical angle so the 2 seal perfectly) when the valve shuts. A multiangle valve job will cut more angles (at least 2) into the valve sealing surface so that instead of looking like this:
|____
______\ <---
... the angle will be more rounded off, which will improve airflow. (man, was it tricky doing ASCII art )
Old Oct 15, 2001 | 02:09 PM
flyry110's Avatar
I'm mad impressed!!!!!! yeah, my jeep had a 4 angle valve job done it. i hear you can do a 5 now but it depends on the number of valves. the more valves, the more noticeable this will be.
Old Oct 15, 2001 | 02:10 PM
flyry110's Avatar
I'm mad impressed!!!!!! yeah, my jeep had a 4 angle valve job done it. i hear you can do a 5 now but it depends on the number of valves. the more valves, the more noticeable this will be. i had a buddy in high school that went to VoTech, so that helped he did all that stuff there.
knight_yyz
Nov 1, 2015 01:34 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
jaydot901
Sep 29, 2015 01:18 PM
