Brake Bleeding - ABS
Old Oct 15, 2001 | 01:05 PM
MadMaxBrent's Avatar
OK, I have read the previous posts on bleeding brakes with ABS. My car manual says to disconnect the negative lead to the battery and to disconnect the ABS actuator.
Question: In all the posts I have read, people have said to disconnect the ABS fuse (I assume the one in the engine bay). Is this effectively doing the same thing as "disconnecting the ABS actuator"?
Any help appreciated,
Brent
Old Oct 15, 2001 | 01:21 PM
NZ Max's Avatar
Re: Brake Bleeding - ABS
Brent
Yep.
Old Oct 15, 2001 | 02:54 PM
kingston's Avatar
What I did was disconnect those ABS plugs in the right corner behind your right headlight. Then you gotta bleed right rear, left rear, left front, right front.
right? I think that's right
Old Oct 15, 2001 | 03:10 PM
OK, thanks for the help guys.
Brent.
Old Nov 20, 2002 | 03:29 PM
superdesi's Avatar
[QUOTE]Originally posted by MadMaxBrent
[B]OK, I have read the previous posts on bleeding brakes with ABS. My car manual says to disconnect the negative lead to the battery and to disconnect the ABS actuator.
Today I replaced one of my rear calipers. I looked for the ABS actuator (mentioned in Haynes) but could not find it. I bled that new installed caliper without disconnecting anything.
Could I have done some sort of damage by Not disconnecting those actuators and/or battery?
Old Nov 20, 2002 | 03:33 PM
Jeff92se's Avatar
I'm needing a caw
Re: Re: Brake Bleeding - ABS
Probably not. I didn't. I think it's a safety issue. If the abs somehow engages while bleeding, I would imagine it would shoot fluid all over the place.
[QUOTE]Originally posted by superdesi
[B]
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
