Does anyone have any idea....
Old Oct 16, 2001 | 09:30 PM
MaxSE's Avatar
why my car best performs on a cooler day than a warmer day? like it really moves.. like a normal max would.. but in warm weather... the acceleration on it.. isn't so great...
any idea's? or is this normal?
Old Oct 16, 2001 | 09:36 PM
Aaron92SE's Avatar
NWP Engineering.com
Re: Does anyone have any idea....
This a problem us VE owners have, called heat soak. The car won't get up and go nearly as fast on days that are over 95 degrees or so. The last time I had the problem was when it was over 100 degrees in Vegas. I have heard that a tranny cooler in the summer months will help a lot. Also, I personally, have cleaned my coolant temperature sensor and it helped the problem. It's getting colder now, so I don't have to worry too much about this problem.
Old Oct 16, 2001 | 09:38 PM
Matt93SE's Avatar
STFU n00b!
this is common with EVERY car.. it's because cold air is more dense, so for every turn of the engine, you're sucking in more oxygen that gets burned inside the combustion chambers to make more power than it would on a cold day.
Old Oct 16, 2001 | 09:40 PM
MaxSE's Avatar
Re: Re: Does anyone have any idea....
Yea it is getting cold here in NY so i have no problem, but i'm takling about when it is like 80 degree's or higher.. is when i get the problem... but i'll look into the tranny cooler...
Also... one time i took my car in the morning.. without letting it warm up just to see how it would act... my brother floored it, and the car peeled out... so much power... but doesn't do that as the car warms up either... what is up with that?
Old Oct 16, 2001 | 09:43 PM
MaxSE's Avatar
Well yea, i understand that part... do you think getting a CAI would make it act as if, just getting up in the morning kinda deal? or not that much power is added? I don't plan to mod this car, i wanna get a 5spd first...
Old Oct 16, 2001 | 09:59 PM
Matt93SE's Avatar
STFU n00b!
When I installed my CAI, it helped quite a bit in the heat soak department, but it's still a BEAST for the first 1-2-3 minutes after starting it up..
I'm going to try and figure out which sensor is causing this change after startup, so I can either fix or disable it.. just need access to a full system scan tool like CONSULT or something while the engine is cold and hot.
Old Oct 16, 2001 | 10:06 PM
Aaron92SE's Avatar
NWP Engineering.com
Oh yeah, please let us all know if you find out how to fix the heat soak or warmed up engine problem. Thanks.
Old Oct 16, 2001 | 10:10 PM
93 SE's Avatar
i know exactly how you feel,im in ny to and i had the same thing,the car was a v8 for the first 10 minutes before the engine temp gets normally warm .I to figured the cai would keep me at that level,but it didnt,so i also got a udp,and tranny cooler, cleaned the TB,temp sensor ,you name i tried it ,they all helped, but i never got to that great power you get in the cold engine stage ...
MATT did you get your pulley yet,and you have got to do something about that handwriting of yours,it hurts trying to read it oh and tell me if you got the gray monster rca cables i cant remember if i put them in or not,im pretty sure i did though ,sorry if it looks bad but it will still do the job,remember its gonna be a tight fit and you'll understand why those scrapes are there trying to get it out
Old Oct 16, 2001 | 10:16 PM
Matt93SE's Avatar
STFU n00b!
Haven't got it yet... don't remember if the mail lady came before I left work today or not!
I told you my handwriting was bad! I was in a hurry anyway!
Old Oct 17, 2001 | 12:32 AM
adamis's Avatar
Does anyone know the equations for air density?
Out of curiosity I was wondering if any of you knew the equations for air density in relation to temperature? I have a temp guage under my hood that I can read while driving and on a HOT day while idling the air being sucked into the intake can be 130 to 140 degrees, maybe more if the car is in stop and go for a long time. If you get on the Freeway then things can cool down to 10 or 15 degrees above ambient. My point is exactly how much more air is there in a Cubic Liter at 70 degreesF then 100degreesF? I think I'll pay a visit to my Chemistry department tommorow and see if there is an equation for this. (There has to be.) It would be interesting to see if all of the gains from a CAI a actually from sucking in cooler air or if it's in combination with having a smoother air flow.
92GXE-Auto
Jacobs Ignition System
Popcharger
A couple of busted exhaust studs!
Old Oct 17, 2001 | 07:21 AM
Booner8269's Avatar
How do you clean the coolant temperature sensor? Is there a post somewere?
OC_Nooby
Jun 13, 2010 09:24 AM
KillaKam
19
Jul 24, 2009 09:55 PM
NixMaxGLE
Jun 20, 2009 08:47 AM
