heater not working
Old Sep 15, 2007 | 04:08 PM
cannondale27's Avatar
heater not working
I have a 1989 max and the heater doesnt blow hot air ,i just put in 180 thermostat and car temp looks aroung middle on the gauge heater is set all the way to hot,i made sure compressor is not running any help would be great as it's going to start getting cold here in oregon.
Old Sep 15, 2007 | 04:17 PM
Greeny's Avatar
¯\(°_o)/¯
You need to bleed the air out of the cooling system (very common issue with the vg engine after you open up the cooling system)
When engine is cold:..Jack up the front end as high as you can get it(atleast 2ft. if possible)/remove radiator cap/start engine,let idle while you are constantly topping off the radiator as it is running,until it will hold no more..
Note: you need to do this procedure until the the engine temp needle is close to mid way(yes,sometime during the process,coolant will "burp" out of the radiator,this is normal,it is the air bubbles in the cooling system coming to the top,and out of the radiator)
Old Sep 15, 2007 | 08:34 PM
the engine temp is getting plenty warm that hot air should be blowing out of vents,it didnt blow hot before replacing stat either thats why i replaced stat ,figured car not getting warm enough.Something must not be right with heater or something when putting it to heat mode it must be staying in cooling or outside air or something in vents not switching the right way,i dont know very confused.The engine temp gets very hot now but air is ice cold blowing out ,ac comp not running.anyone
Old Sep 15, 2007 | 08:36 PM
Soaknfused's Avatar
Do you have manual or auto climate control? and did it just stop working abruptly or gradually over time?
Old Sep 15, 2007 | 08:39 PM
Matt93SE's Avatar
STFU n00b!
sounds like its time to flush the coolant system and check the bypass valve.
Old Sep 16, 2007 | 01:58 AM
alextothestars's Avatar
heh. could be water pump going (hasnt GONE yet). not very descriptive about the problem...
Old Sep 16, 2007 | 03:47 AM
maximagician's Avatar
is the heater valve more prone to stay stuck open(hot in) or closed (no water in?) have some one switch the temp slider from full cold to hot while
looking at the valve arm around where the middle of the firewall is also
Old Sep 16, 2007 | 05:50 AM
sublunary's Avatar
do what green said and bleed the air first, 95% sure that is your problem, then post back if that doesn't work
Old Sep 18, 2007 | 06:24 PM
maxima-junky's Avatar
Oh check the floor on the passenger side. See if there is coolant in the carpet. If so. Heater core is done.
Old Sep 18, 2007 | 08:49 PM
gapboi210's Avatar
or heater core could be clogged
Old Sep 18, 2007 | 09:13 PM
hadman's Avatar
+1 to bleeding air out of the system. It is almost always the issue with VG's. I've been using this method for several years.
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
iflexsteel
Sep 2, 2015 08:04 AM
Hailstatejig
Sep 2, 2015 06:52 AM
