electrical brake light problem
Old Oct 17, 2001 | 05:08 PM
dnas420's Avatar
Ok here is the problem i have no brakelights. I have taillights and for some reason the fuse keeps blowing for the brakelights when i replace it and hit the brake pedal. I have inspected my taillamp panels for corrosion but none. and i know that one of the bulbs melted the plastic where it was screwed in o it kinda dangles but i dont think this is the problem. It has been like that for a while before this problem arose. Any other ideas to find the problem please share.
Thank you
Old Oct 17, 2001 | 05:53 PM
«§»Craig B«§»'s Avatar
Re: electrical brake light problem
Thank you
disconnect both brake lights assemblies (from inside the trunk) -small harness at teh bottom
test pedal
didn't blow fuse? - problem is in one of the assemblies
plug left one in and test
didn't blow fuse? - problem is probably in right one
plut right one in and test
blow fuse - problem in this one, check all wires and replace if necessary
or repeat procedure with sides switched
you get the idea
try to isolate the problem
tsi6001
Oct 3, 2022 10:23 PM
JMag90
Aug 25, 2015 09:17 AM
Nismo_Guy89
Aug 24, 2015 09:49 PM
Samedi
Aug 13, 2015 04:05 PM
