Transmission
Old Nov 11, 2007 | 08:34 AM
  #41
raygord's Avatar
I dont believe its quite so cut and dry
Old Nov 11, 2007 | 03:26 PM
  #42
EcDunson's Avatar
Hi, I have a 92 Maxima body with an 89 motor(3.0 SOHC) and an auto tranny. My mechanic and I put a full gasket set on the motor and changed the tranny fluid. The car idle's fine but when put in gear it drops below parked idle. When it is driven it accelerate at a fast rate, it just slowly moves. We used the top of the intake from the motor it came out of because of the fuel injection and most of the components(alternator, battery, distributor, cap, rotor, power steering) were brought new within a year. Does this sound like a tranny computer problem from the switch of the years? If so where could I hook a tester up to the car to find the right code to find out?
Old Nov 11, 2007 | 07:18 PM
  #43
helps
did the car have a ve engine in it before hand? when i had a ve ecu in a vg the check engine light would come on at like 3500 rpm. i figured it was because it wasn't twin cam. car wasn't sluggish though but was a 5 speed.
Old Nov 11, 2007 | 07:32 PM
  #44
nlt624's Avatar
I had an 89 GLE with the same problem with the transmission. I was not about to pay $1800 to replace it, so I traded it in with 316,000 miles on it and got $3000 for it because the appraser liked the digital dash (that didn't work when it was cold).
Old Nov 11, 2007 | 07:35 PM
  #45
CapedCadaver's Avatar
Call me Wookiee Goldberg
i would assume he meant a 92gxe.. because of this "We used the top of the intake from the motor it came out of because... " indicating he took parts from the 92 motor to put on top of the 89.
no such thing as GLE until 95. not in the USA at least. Where are you?
user 11122324
42
Jul 18, 2022 03:35 PM
Pied
Sep 26, 2015 03:29 PM
