Transmission
Old Sep 26, 2007 | 10:00 AM
MissingNAxion's Avatar
Noob wanting more
Transmission
I think i have a transmission problem in my '90 SE and i was wondering if anybody had a clue what was going on. When i shift gears from park to drive, i have to go PAST the D down to the 2 and THEN go to the D, otherwise the car things its in neutral, its like the wire is stretched a little bit or something. Any help would be amazing. Haha, what a funny smiley:
Old Sep 26, 2007 | 10:09 AM
internetautomar's Avatar
mod or sell?
as I said before:
Shifter Bushing
Old Sep 26, 2007 | 10:13 AM
Greeny's Avatar
¯\(°_o)/¯
http://forums.maxima.org/showthread.php?t=404196
Old Sep 26, 2007 | 01:46 PM
1992GXE's Avatar
dude...that sucks. as we speak, my tranny is getting rebuilt for $2,032
OUCH!
Old Sep 26, 2007 | 04:40 PM
Deridex's Avatar
OUCH!
Holy crap, man. That's more than entire car would cost. Why not just go to a local junkyard and get a used one that works instead? That cost me $600 with labor, and the replacement transmission seems to work just fine.
Old Sep 26, 2007 | 04:52 PM
Greeny's Avatar
¯\(°_o)/¯
OUCH!
Joo got ripped mang.
Old Sep 26, 2007 | 05:27 PM
Tom's Avatar
Tom
That was my thread from not too long ago...
The part # is 34552-D4000.
I put my car on jack stands, got underneath the car and removed the bolts holding the catalytic convertor heat sheild on. I wiggled the heat shield off and and you will see the shift linkage toward the driver's side of the car.
My original shifter bushing was completely gone.
I disassembled the linkage, installed the new bushing, put the heat shield back on and I was in business again, in about 20 minutes.
Note: I waited 2 hours for the catalytic convertor to cool.
Old Sep 27, 2007 | 09:11 AM
Noob wanting more
thanks guys. im going to go to the dealer after college 2day and look that part up. Thanks a whole lot.
Old Sep 30, 2007 | 11:52 AM
1992GXE's Avatar
yeah dude, i know haha. im finding a new place to do it now...the price sucks, but the fact that i wont have a car for a week sucks too
Old Oct 5, 2007 | 09:05 AM
Noob wanting more
Thanks everyone for helping me, i bought the part and went under th car and put it in. I got a deep cut into my thumb by the edge of the heat plate above the catalytic convertor, but i guess it was worth getting my car running smoothly. Thanks for the help, it works just fine now, and now i have decided that I will be the only one working on my car b/c i found an old rag under the car from where somebody in the past had worked on it. That was the third i have found so far. Stupid mechanics, clean up after yourself!
Old Oct 24, 2007 | 12:39 PM
starkviller's Avatar
hi guys, that's exactly what happened to my car in the last two weeks, and thanks god, finally got the answers.
Old Oct 28, 2007 | 10:21 AM
peaksja's Avatar
Now that's exactly why I am proud to be a member of this site. The answers are always posted or no one really crys if someone does not use the search engine first.
I just bought my max swapped in a newer engine and trans and have the same issue, now within 4 mins I found the answer and part#.
Old Oct 28, 2007 | 11:05 AM
Maximahappy22's Avatar
congratulations just don't bump an old thread to be a post *****...
Old Oct 31, 2007 | 08:09 PM
RobReyes's Avatar
93 Automatic Transmission Question
I heard that all 93 automatic transsmisions were defective is that true?
'Cause I have mine down and I want to replace it, but still dont know whats the best option.
Could someone help me.
Thanks.
Old Oct 31, 2007 | 08:12 PM
mod or sell?
Thanks.
is your 93 DOHC or SOHC?
Old Nov 1, 2007 | 06:58 PM
RobReyes's Avatar
How can I see what kind of Engine do I have??
Old Nov 1, 2007 | 07:05 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
um. does the air duct from your airbox to your engine snake all over the darn place, or is it a short, mostly straight line?
former is a VG, latter is a VE.
http://btp.mine.nu/Jared/NewCam/IMG_0007.jpg this is a VG
Old Nov 1, 2007 | 07:08 PM
Matt93SE's Avatar
STFU n00b!
easiest one to start with.. what color are your gauges?
(assuming the car is 100% original...)
white gauges = SE model. DOHC engine.
black gauges = GXE model. SOHC engine.
the 89-91 models had an insanely weak tranny. the 92-94 SOHC was much better, but still on the weak side.the 92-94 DOHC model has the strongest transmission, but unfortuantely isn't (easily) transferrable to a SOHC engine.
Old Nov 1, 2007 | 11:09 PM
Deridex's Avatar
I've a question. When I drain all the tranny fluid, are the CV axles supposed to rotate even when the shifter is in "P"? I jacked up the car, took off both wheels, and the left axle seemed to rotate rather freely when I held on to it.
Old Nov 2, 2007 | 08:48 AM
mod or sell?
open hood and read if it says 24 valve or not
does it have a distributor?
Fourth digit of the VIN "H" is a SOHC
Fourth digit of the VIN "E" is a DOHC
Old Nov 2, 2007 | 05:12 PM
since you have a GXE, which has an open diff (ie, not a VLSD as you learned about in the 'Tranny-Engine mating question' thread), and since Park just locks the diff casing and not the individual axles, then if you jack it up you can spin the wheels, but the other wheel should be spinning the same speed in the opposite direction.
Old Nov 2, 2007 | 10:45 PM
Deridex's Avatar
A ha! That explains it. Thanks man.
Old Nov 3, 2007 | 07:31 AM
maxima-junky's Avatar
Long term
If your looking to keep that car long term get your transmission rebuilt by a professional. If it cost 2k to rebuild keep the receipt that raises the value of a vg considerably. Make sure you opt for the fluid cooler because its heat that is the biggest enemy of these trannys. I spent $1,800 to rebuild a transmission in a 91 se that i paid $500.00 for. I got $2,300 for the car when I sold it some years later (car was in excellent cond. of course).
Old Nov 5, 2007 | 02:28 PM
RobReyes's Avatar
Its a " SOHC ", sorry for the late response, but I really need the help of all of you.
for my 93' , Can I use a 95 o newer tranny??
Old Nov 5, 2007 | 02:49 PM
Greeny's Avatar
¯\(°_o)/¯
Nope,won't work..
Old Nov 5, 2007 | 05:13 PM
mod or sell?
maybe a 95 newer one from a quest, but no one has checked it out yet
Old Nov 5, 2007 | 05:25 PM
traxtar944's Avatar
Would be lost w/out the org
Now that would be something worth looking into. Too bad nobody wants to experiment with stuff like that.
You're talking about the VE 5speed trans or the VE auto trans?
Old Nov 5, 2007 | 05:54 PM
RobReyes's Avatar
Auto Trans
Old Nov 5, 2007 | 06:01 PM
Matt93SE's Avatar
STFU n00b!
Auto.......
Old Nov 7, 2007 | 04:44 PM
RobReyes's Avatar
What should I do??? I don't have enought cash to repair it, and I like this car
Old Nov 7, 2007 | 05:30 PM
gapboi210's Avatar
fred flinstone it
Old Nov 7, 2007 | 05:46 PM
Greeny's Avatar
¯\(°_o)/¯
You only have one option,save/borrow/get a loan to fix or replace the transmission..
Old Nov 7, 2007 | 06:01 PM
Darkwing48's Avatar
Then there's plastic. I plastic my car for 3,100 and still paying for it. If I can get a house, I'll DIY like you guys
By the way, where can I find the FSM manual and that diagram in the link? I couldn't find it in the stickies. PM me.
Old Nov 7, 2007 | 06:55 PM
mod or sell?
PDFtown has a lot of FSMs
Old Nov 8, 2007 | 06:53 AM
I changed the shifter bushing two weeks ago. problem solved, and the starting problem is gone.
Thanks,
Old Nov 9, 2007 | 05:17 AM
raygord's Avatar
other tranny problems
I have the same problem with the shifter so now I know how to fix that. I have another problem though. Since cold weather set it. On really cold mornings I start driving to work. car will start going just fine then as I get up around 20 to 40 mph its like it just slips out of gear and the engine revs up high. I can put it back into nuetral and back into gear and it will usually start working again. Sometimes takes a couple of times. After driving for about 5 mins it stops doing it. I assume because the tranny has warmed up and what ever it is causing the problem, shrunken seals????? slow moving fluid ???? has returned to normal operation.
Any ideas. As I said this only happens on cold mornings.
Old Nov 9, 2007 | 05:25 AM
Noob wanting more
yea, i had the same thing happen to e the other day and it scared the hell out of me. I thought the bushing i had JUST put on there had just slipped out or melted AGAIN! Idk what the prob is either,sorry man.
Old Nov 9, 2007 | 07:03 AM
mod or sell?
just drop the pan and CHANGE the trans fluid. don't flush it.
if you have a VE, change the screen too, or at least clean it.
Old Nov 9, 2007 | 10:37 PM
raygord's Avatar
I just drained and flushed the fluid less than a year ago
Old Nov 10, 2007 | 04:42 PM
mod or sell?
you flushed?
oh well, then you need a new tranny
