Odd Shift Interlock Prob
Old Nov 3, 2007 | 02:09 PM
gapboi210's Avatar
I noticed that shift interlock seems to work fine. If the car is off, the shifter is locked. When I start it, it is locked until I step on the brake. However, after starting the car, if I let it run for about 15-20 seconds I hear a click and the lock is disengaged and I don't have to step on the brake to get it out of park. It doesn't bother me but wondered what would cause this.
Old Nov 3, 2007 | 04:42 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
possibly a short in the system, or a bad controller. Mine used to click like a crackhead before the controller died, and this would happen even if my foot was off the brake.
Old Nov 4, 2007 | 05:12 PM
gapboi210's Avatar
I wonder is something is loose. It didn't start to do this untill I reached down there to get the bulb out of the gear indicator.
Old Nov 4, 2007 | 05:46 PM
a sensor or harness could have been undone accidentally when you did that. You may want to make sure that all 4 harnesses are hooked up and all.
Old Nov 5, 2007 | 06:25 AM
Giddy01's Avatar
I have the same problem, please let me know how you resolved this problem.
Old Nov 6, 2007 | 11:53 AM
gapboi210's Avatar
thanks for letting me know there are 4, are they all there in the shifter area?
Old Nov 13, 2007 | 07:32 PM
1990maxGXE's Avatar
I have this same problem when i would put my foot on the brake after starting the car it would click like crazy and i could normally get it into gear and then it just stopped
so i have to manually put it into gear now where is the controller at?
Old Nov 13, 2007 | 07:38 PM
Greeny's Avatar
¯\(°_o)/¯
---> http://forums.maxima.org/showthread.php?t=379422
Old Nov 14, 2007 | 06:17 PM
1990maxGXE's Avatar
THanks for pointing me in the right direction ill try to fix it over thanksgiving
Old Nov 14, 2007 | 08:59 PM
im' stupid. I meant 2. there's 4 things controlled but it's just 2 harnesses. items are illumination, od switch, shiftlock solenoid, and park switch for shift/keylock.
don't remember which harnesses have which but it's 2 a piece.
Old Nov 14, 2007 | 09:16 PM
augiedog964's Avatar
Mine has a similar problem, only works when ignition is on. I can shift the car into gear with the key out of the ignition, it makes a loud click when i push the button. Could end up being a safety issue if someone messes around with it
Old Nov 14, 2007 | 09:25 PM
shift lock should only actuate when car is in the ON position (whether running or not), in park, foot on brake. shifter button should not push in when you have the key out or foot off brake, while in park. of course it will push if you are not in park, because the lock only works in park (after you let go once, of course)
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
