AC/Heater Floor setting acting weird
Old Nov 29, 2007 | 09:52 PM
gapboi210's Avatar
My ac controls have always worked normally. I noticed the other day that when I put it on floor, it is blowing on floor and defrost. If I select the floor and defrost option it blows a little more on the defrost like it should. So it acts like on the floor setting that something is not opening or closing all the way. I looked under the dash and watched the doors move when I changed the settings. Everything seems to be moving smoothly.
What else can I check?
Old Nov 30, 2007 | 01:43 PM
Maxteca's Avatar
Mine did that a long time ago and one of the doors on the heater box that controls the vents was not closing all the way. So you might check that out.
Old Nov 30, 2007 | 05:15 PM
Hectic's Avatar
You gotta adjust your mode door, check the FSM for the procedure.
Old Nov 30, 2007 | 06:40 PM
Maxteca's Avatar
If you have auto climate control here is a link on how to adjust the mode doors. Its down at the bottom of the page.
http://www.geocities.com/cbmaxima/maxima/ACC/ACC.html
Old Nov 30, 2007 | 06:54 PM
gapboi210's Avatar
I have manual controls. Do I stll need to adjust?
Old Nov 30, 2007 | 07:14 PM
gapboi210's Avatar
I just read the FSM and under the part that says Control Linkage Adj, it just says how to install it, not adjust.
Old Nov 30, 2007 | 07:28 PM
ColombianMax's Avatar
I'd figure installing is somewhat related to adjusting
Old Nov 30, 2007 | 08:04 PM
gapboi210's Avatar
just says to bolt the bitc# on
Old Nov 30, 2007 | 09:35 PM
Maxteca's Avatar
Look at the mode doors while someone runs it through all the settings. Thrust me you will see how to adj it.
alphakaoz
Sep 30, 2015 07:33 PM
05RLS2
Sep 27, 2015 09:24 PM
yamehoo
Sep 24, 2015 10:21 AM
Domf3
Sep 22, 2015 03:05 PM
