Idle fluctuation when brake applied
Old Dec 10, 2007 | 03:16 PM
redwood_usa's Avatar
When the car is idling and I press the brake, the engine reve move up and down about 300 revs. Is this normal or a problem. the car idles rough.
Old Dec 10, 2007 | 03:30 PM
Greeny's Avatar
¯\(°_o)/¯
Sounds like a vacuum leak.
Old Dec 10, 2007 | 03:32 PM
Matt93SE's Avatar
STFU n00b!
the idle will move a little bit because the brake is vacuum assisted, but 300rpm is a bit much.
check the large vacuum hose (about 1/2") running form the manifold to the brake booster for leaks.
when someone presses on the brake, listen for air noises aorund the brake booster as well to see if the diaphragm is leaking.
could also be the check valve on the booster line.
those are the most common places to see issues here.
last thing..
when you press the brake down, which way does the RPM move? up or down?
does it stabilize while you have your foot on the brake, or does it only go back to normal idle when you let off the brakes?
Old Dec 10, 2007 | 03:53 PM
Originally Posted by Matt93SE
last thing..
Idle moves down when the brake is pressed
it stabilizes at the lower RPM if the brake is kept depressed and goes back when released
Old Dec 10, 2007 | 05:37 PM
Matt93SE's Avatar
STFU n00b!
sounds like a vacuum leak inside the booster.. when you have someone push the brake, stick your head near the booster and listen for hissing.
Old Dec 10, 2007 | 06:06 PM
If thats what it turns out to be, whats the solution ? replace the booster ? JY part or new? Or is it fixable.
Old Dec 10, 2007 | 07:01 PM
internetautomar's Avatar
mod or sell?
it is fixable, but not by the average mechanic. mostly due to lack of parts.
a rebuilt booster should be in the $100 range.
Old Dec 10, 2007 | 07:06 PM
Matt93SE's Avatar
STFU n00b!
what he said.
Old Dec 11, 2007 | 01:18 AM
ColombianMax's Avatar
what he said.
lol looks like Matt is always gets beat to posting the solution..recently at least, I've seen quite a few of these already. isnt it a great feeling when you can just say that?
Old Dec 11, 2007 | 05:59 AM
Matt93SE's Avatar
STFU n00b!
actually I nailed the problem my first post. the rest of the thread was spent helping him diagnose the issue. Brian was about 4 hours behind.
Old Dec 11, 2007 | 06:04 AM
Doesnt that feel great too
Old Dec 11, 2007 | 06:36 AM
mod or sell?
some of us have lives
I unfortunately was at the hospital visiting a friend in the BICU
Old Dec 11, 2007 | 07:24 AM
Fixed.The screw down clip on the hose from the plenum to the booster was loose. Amazing how much trouble that caused , even though the hose itself was properly.
Old Dec 11, 2007 | 08:57 AM
maxitech's Avatar
*cough* postwhore! *cough*
Old Dec 11, 2007 | 09:31 AM
Matt93SE's Avatar
STFU n00b!
Heh... that was easy. at least it was cheaper than a brake booster! (And I still nailed it in my first post. )
Old Dec 11, 2007 | 02:59 PM
You really think so? I've never considered myself that bad of a *****.
Old Dec 11, 2007 | 03:01 PM
Greeny's Avatar
¯\(°_o)/¯
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
