Help Help Help!!!!
Old Oct 26, 2001 | 09:56 PM
Antonio
Help Help Help!!!!
Hey everybody!!
Today, as I was driving along in my Maxima '93 suddenly my dash lights went out. I stopped and checked all of the fuses and found out that my rear lights fuse had burned out. I changed the fuse but it blew again as soon as I put it in. I dont know what is the problem, the rear light fuses just keep on blowing. Plese tell if you know why this is happening and how to fix it. I would really appriciate your help!
Thanx!
Old Oct 27, 2001 | 05:47 AM
nubiannupe's Avatar
OG Maxima.org Member
I can tell you WHY it's happening (dead short), but you'd need to check your wiring to figure out where the problem is originating.
Good Luck!!!
Old Oct 27, 2001 | 12:57 PM
dmontzsta's Avatar
Ford Only.
Exactly, If you cant find the problem immediately you can put a 15 amp fuse in. But the problem will be in your back lights, look for any burnt wiring, and make sure there is no wiring touching.
