Big Brake Question
Old Feb 22, 2008 | 08:01 PM
maxima-junky's Avatar
Big Brake Question
What mods would have to happen for Q45 calipers to fit a 92se?
Old Feb 23, 2008 | 01:57 AM
Greeny's Avatar
¯\(°_o)/¯
The search function....
Old Feb 23, 2008 | 05:53 AM
maxitech's Avatar
Buy Q45 calipers, pads, and rotors...turn about 3mm off of the rotors, cut a notch in the pad shims for proper clearance...lather, rinse, and repeat...
Old Feb 23, 2008 | 11:18 AM
goon9's Avatar
I heard you can use maxima pad, rotors, and g45 calipers. Maybe Greeny can elaborate?
Old Feb 23, 2008 | 11:54 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
Q45 or G35?
Old Feb 23, 2008 | 12:16 PM
goon9's Avatar
Originally Posted by capedcadaver
Q45 or G35?
meant Q45.
Old Feb 23, 2008 | 03:49 PM
Greeny's Avatar
¯\(°_o)/¯
I heard you can use maxima pad, rotors, and Q45 calipers. Maybe Greeny can elaborate?
Yes they will fit, as long as you don't run your pads all the way down to the squealers. About 1/3 pad material left is as far as you would want to go. you also have to do a little dremel work on the maxima torque member.
I done this as a test just see if it could be done, then just left them on..
Old Feb 23, 2008 | 06:59 PM
DanNY's Avatar
Ad·min·is·tra·tor
it's the same procedure as the Z32 calipers
Old Feb 23, 2008 | 07:29 PM
Greeny's Avatar
¯\(°_o)/¯
not rly..
Old Feb 24, 2008 | 08:40 PM
DanNY's Avatar
Ad·min·is·tra·tor
Originally Posted by Greeny
not rly..
i thought all RWD calipers fit that way on the max...or from the Q45 and Z32...no?
Old Feb 25, 2008 | 04:22 AM
Greeny's Avatar
¯\(°_o)/¯
I don't know the exact details involved in the z32 caliper swap, but the q45's will bolt up to the maxima torque member with minimal work. just a little grinding on the torque member, along with some pad shim modifications. In the end, this mod is still in the testing stages for me, i am still monitoring how far the maxima pads can go before the caliper pistons are at their travel limit. So no golden seal of approval from me atm.
BkGreen97
Apr 2, 2016 05:47 AM
bbsitum
Sep 11, 2015 04:55 PM
beerman1378
Sep 8, 2015 02:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
