ventilation fuel hose leaking
Old Feb 27, 2008 | 08:46 PM
wawa92gxe's Avatar
Mine is leaking. It is the small rubber hose on the thinner metal tube that runs parallel to the big metal filler tube.
I assume an easy fix but noticed really tight space there. I tried and can't get a good grip on it...
Any tricks to get the sucker off and put the new one on? Do i have to drop the tank ? I really hate to work on gas tanks...
BTW, what size is that rubber hose ?
TIA.
Denga
Old Feb 28, 2008 | 02:43 AM
redwood_usa's Avatar
TIA.
Denga
http://www.courtesyparts.com/betasit...1627_1631.html
[url]http://www.courtesyparts.com/betasite/kb_search_result.php?keywords=[17226]+\(j30&cPath=1610_1611_1627_1631[url]
Its got 2 clamps, one on each end. Once you get the clamps off you can just cut it off. Its easy if you remove the left rear wheel.
Old Feb 28, 2008 | 05:35 AM
wawa92gxe's Avatar
Thanks!
Do you know the size of that hose?
I will probably pick up some from local store.
It will take several days to get from the Dealer.
Old Feb 28, 2008 | 08:44 AM
subs1000w's Avatar
i would just wait till you have it off then go buy one so you know you get the right size
Old Feb 29, 2008 | 12:10 PM
Deridex's Avatar
I had the same problem a while back. I just patched up the old hose with some vynil tape i had laying around. Worked fine so far. Though it was a b1tch to get to it.
Old Mar 3, 2008 | 04:17 PM
wawa92gxe's Avatar
I replaced it on Saturday. It took me only 3 min to get it off. Afer removing the clamps, I cut open and disconnected the hose in the rear, and then use a locking plier to pull it off. But it took me 1 hour or so to put the new part on. The place is really tight. After some cursing and scratching on my fingers, i got it on right. The hose i used was 5/8 ID fuel hose from Napa. The OEM one was 9/16, i believe, and i couldn't get one without waiting another week.
Old Mar 3, 2008 | 04:20 PM
IBut it took me 1 hour or so to put the new part on. The place is really tight. After some cursing and scratching on my fingers, i got it on right. The hose i used was 5/8 ID fuel hose from Napa. The OEM one was 9/16, i believe, and i couldn't get one without waiting another week.
It should have taken you 5 mins to put it on. Sorry I did not tell you to WD 40 the inside of the hose before slipping it back on. But I thought You would know that.
Old Mar 4, 2008 | 07:03 AM
wawa92gxe's Avatar
I did WD40. But i should have trimmed the hose to exact length... At the beginning, i tried to put it on with about 3/4 inch longer and it really sucked.
Then another issue was that the aftermarket hose was rigid like steel, not even close to the flexibility of the OEM, which made things worse at the tight space.
Old Mar 4, 2008 | 04:00 PM
Yep , those 2 combinations made it a pain.
Old Mar 25, 2008 | 03:39 PM
Tampamaximus's Avatar
Just replaced this on my car. What a pain. Gas milage is much better and I dont smell fuel when im backing up now.
conansriver
Nov 18, 2015 02:46 PM
MaxDD
Sep 24, 2015 06:40 AM
bumpypickle
Sep 20, 2015 08:22 AM
aminus21
Sep 12, 2015 04:53 PM
dcam0326
Sep 7, 2015 07:26 AM
