Door locks stopped working
Old Mar 1, 2008 | 10:47 AM
jmichaelrush's Avatar
Door locks stopped working **Problem fixed, but now new one**
Kind of a weird situation here. My doorlocks stopped working temporarily about a month ago when it got really cold all of a sudden, then they started working again the next day when it warmed up. Well, it got really cold a couple nights ago, and guess what, the locks stopped working again. I figured they would start working again when it warmed up, like last time. Nope, wrong.
Whenever I press the lock switch I can hear a click under the dash(like a relay) but the locks don't want to work. Any ideas?
Old Mar 1, 2008 | 11:51 AM
Gunther's Avatar
http://forums.maxima.org/showthread.php?t=400717
but mostly this:
http://www.thewardrops.com/maxima/
Old Mar 1, 2008 | 12:26 PM
MaximaN00b's Avatar
mine locks itself, it locked me out once!
now i leave a window cracked when i warm my car up, it sucks.. i have to read those threads, maybe it says something about my problem
Old Mar 1, 2008 | 05:00 PM
internetautomar's Avatar
mod or sell?
door lock timer
links in post #2
Old Mar 2, 2008 | 11:21 AM
Thanks Gunther The locks work now with the fix, but a new problem arose.
New problem:
Whenever I got everything put back together from the TCU fix, I shut my door and all the doors locked. Well, my sunroof was opened so I just reached inside and unlocked the passenger side manually, and in doing so, set off the Anti-theft system. I unplugged the Atni-theft box underneath the steering column, but my question now is, How do I reset the anti-theft? I lost my real key, so now I only have a valet key. I am going to get another real key for it, but just haven't had the time in the past few weeks.
Old Mar 2, 2008 | 11:38 AM
mod or sell?
New problem:
the alarm is reset by locking and unlocking the passenger door with the key IIRC
Old Mar 2, 2008 | 12:13 PM
Gunther's Avatar
I think you have to wait for the alarm to shut off, then open the door with the key. It's happened to me a few times, I usually pull the relay for the horn until the alarm shuts off, open the door with the key, and replace the relay
Old Mar 2, 2008 | 01:21 PM
BenStoked's Avatar
Jesus was a Zombie.
ive locked the doors back(with alarm honking) and unlocked them with the key. killed the alarm...
Old Mar 2, 2008 | 04:16 PM
Gunther's Avatar
I've got an aftermarket alarm as well [last owner installed it] and the stock one wasn't disabled. It might be interfering with turning the alarm off
Old Mar 2, 2008 | 04:21 PM
vernk's Avatar
unlocking the drivers door with the key should turn the alarm off if not disconnect the battery for for 30 sec will reset factory alarm iirc
Old Mar 2, 2008 | 04:22 PM
maximaman1313's Avatar
how do you disable the stock alarm without screwing with aftermarket alarm?
BTW: I had the lock problem too, stoped working all together, saw this post and decided to go buy a soldering iron. took me 25mins to take off bottom part, remove thing, solder, test, put all back together. first time using a solder.
Locks work again!! Thanks for the Info!
King_Ten_Ahead
Sep 30, 2015 04:27 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
MidnightMaxima_22
Aug 19, 2015 01:01 PM
shaunkey1
Aug 18, 2015 10:09 PM
kjm900r
Aug 5, 2015 07:14 AM
